Hello,
After I upgraded from NethSecurity 8-24.10.0-ns.1.6.0 to NethSecurity 8.7.1, the two WAN interfaces on the Slave router don’t come up.
What I did:
- Upgrade of Slave and Primary routers to NethSecurity 8.7.1
- ns-ha-config reset
- Configuring keepalived.
After configuration the status is OK, I stop Primary and Slave becomes Primary now, but the WAN interfaces are down.
The VIP IP address moves between primary and slave
Any idea what the problem is?
I noticed perhaps two problems:
- in /etc/init.d/mwan3 restart there is a syntax error:
# /etc/init.d/mwan3 restart
grep: warning: stray \ before :
Fixed by replacing on line 80:
from
for rule in $($IP rule list | grep -E '^[1-3][0-9]{3}\:' | cut -d ':' -f 1); do
to
for rule in $($IP rule list | grep -E '^[1-3][0-9]{3}:' | cut -d ':' -f 1); do
- When I try to run keepalived debug, I get an error with reload_config
[P]:~# uci set keepalived.primary.debug=1
[P]:~# uci commit keepalived
[P]:~# reload_config
uci: Entry not found
[P]:~#
For point 2, I have no idea why it’s giving an error.
Best Regards,
P.S.: I forgot to add, I tried to do ifup wan1, but it has no effect. I had added the option option auto '0', I removed it manually, restarted, it doesn’t help. For some reason this option appeared again. This is the config of one WAN
config device 'ns_50cf3728'
option name 'eth0.11'
option type '8021q'
option ifname 'eth0'
option vid '11'
option ipv6 '0'
option macaddr '00:AA:BB:CC:DD:EE'
config interface 'wan1'
list ns_tag 'ha'
option auto '0'
option device 'eth0.11'
option proto 'dhcp'
option hostname '*'
option force_link '0'
option metric '30'
Do you see anything wrong in this config?
