first of all: I’m lazy, and I’m looking for a way to not manually reinstall all installed packages (like zabbix-agentd and other utils) from openwrt repositories when I do a “system update”.
Furthermore, I would like not to lose the bash history.
what I’m doing now:
I use opkgscript.sh to save the list of installed packages
then I use a script that configure customfeeds, calls opkgscript.sh and then cleans customfeeds.conf
furthermore i added some dir/files in /etc/sysupgrade.conf
I was wondering if there is a nicer/better way to get a “full restore” after a system upgrade
other questions:
will there be a way to see the latest connections of an openvpn roadwarrior user (like ns7) implemented?
is there or will there be a way to see the update changelogs before applying them? especially in this testing phase it would be useful to understand the fixes and better understand what to test. I really miss it
I thought I had more questions, that’s all for now
I’d say that’s the correct approach. We can evaluate to keep some customization like yours, but I fear it will not be easy to make it work with OpenWrt backup/upgrade implementation.
there is no sqlite cli, you need to use python to see what’s inside the db
data are lost upon reboot to preserve the storage lifespan
I miss them too The OpenWrt package system is very poor, there is not such thing like a changelog.
We could try to generate it for all ns-* packages (packages maintained by us) using the git history but it’s not easy at all.
yes I understand, no probs. only one other doubt: I put my scripts in /etc/config… is that okay or is it cleaner to use another dir? maybe in /mnt/data ?
ok good to know, it’s not a big problem for now, I’ll see if I can get some data or if ns8 controller can be of help
I’ll keep checking on github for package update
but maybe for System Updates (after stable, when I imagine the releases will be less frequent) we can think of a summary screen like opnsense?
