Nethsec SQUASHFS error: Unable to read directory block
Hello folks,
After loosing my Motherboard and replacing with a new one, I’m having the system boot, the network works, I can access via SSH but nothing else works.
Is there a way for me to backup and restore?
Thanks,
Sounds like a disk error.
Is it the same motherboard or a different one?
Does it work to reinstall and restore from a backup?
Maybe it’s possible to restore via the api?
Hi @mrmarkuz,
Thank you for your swift reply!
This feature is only available to subscribed users. Which is not my case, it’s a small office with only a few users.
I ended it up installing DinFy instead!
Thanks,
