Nethsec send SMTP
Hello,
on NS7 i configured SMTP settings to send notification email from itself and other servers on my lan using port 25 on the firewall. Only have to configure firewall ip and port 25 on my service and ns7 send emails without problems.
Is there the same service on nethsec 8?
I successfully configured msmpt but i can’t send email from LAN, only from msmtp command.
Thank you.
No: there is no SMTP server included.
msmtp is just a SMTP client and can be used only for programs running on the firewall itself.
If you want, you can install postfix from the upstream repository.
If postfix it is not available out of the box, I prefer to setup another Postfix server and let nethsec just do its job, the security firewall. Thank you.
