Nethsec certifcates from letsencrypt
I’m testing Nethsec and trying to get the letsencrypt to receive a certificate!
Do I need to open ports to receive the certificate, or would this be automatic when I request it?
The status stays in Pending
I use BIND to manage DNS and have no API.
Thanks,
If the firewall is behind another router that connects to the web then you need to open a port on the outer router if you use HTTP challenge.
NethSecurity opens port 80 during obtaining LE certs.
DNS challenge is also possible without opening ports.
For more details see Certificates and reverse proxy — NethSecurity documentation
OK, so when I I tried getting the certificate I added all my domains on the same requisition. This didn’t work.
Now if I request one by one, then it works!
Thank you @mrmarkuz
