hucky
(kai)
March 24, 2018, 6:04am
1
NethServer Version: 7.4.1708
Module: nethforge-test-repos
Since a couple of days i am not able to install stuff from the test-repos. if i try to update sogo or rspamd i got
Error getting repository data for nethforge-testing, repository not found. somebody else have that problem?
mrmarkuz
(Markus Neuberger)
March 24, 2018, 10:11am
2
Hi @hucky ,
Nethforge-testing working here.
Is the repo file ok?
[root@testserver ~]# cat /etc/yum.repos.d/NethForge.repo
[nethforge]
name=NethForge $releasever
mirrorlist=http://mirrorlist.nethserver.org/$releasever/nethserver?release=$releasever&repo=nethforge&arch=$basearch
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/nethforge/$basearch/
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethForge-7
enabled=1
enablegroups=1
[nethforge-testing]
name=NethForge $releasever - Testing
mirrorlist=http://mirrorlist.nethserver.org/$releasever/nethserver?release=$releasever&repo=nethforge-testing&arch=$basearch
#baseurl=http://packages.nethserver.org/nethserver/$releasever/nethforge-testing/$basearch/
enabled=0
enablegroups=1
You may try to clean all:
yum clean all
yum update
Do you use IPS? You may try to deactivate it as it may block yum.
hucky
(kai)
March 24, 2018, 3:01pm
3
i had a wrong repo file in /etc/yum.repos.d, dont know why, now it seems to work thanks for your answer
hucky
(kai)
March 24, 2018, 3:23pm
4
but something is wrong with that file⦠with this:
# nethserver.org YUM repositories configuration
[nethserver-base]
name=NethServer-$releasever - Base
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=base&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/base/$basearch/
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-$releasever
enabled=1
enablegroups=0
[nethserver-updates]
name=NethServer-$releasever - Updates
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=updates&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/updates/$basearch/
enabled=1
enablegroups=1
[nethforge-testing]
enabled=0
enablegroups=1
Konfiguration i dont get the Testserverā¦
dnutan
(Marc)
March 24, 2018, 3:33pm
5
You can compare the repo files with the original ones:
