Netdata Stats Proxy dont work
NethServer Version: 7.6.1810
Module: Web Proxy & Filter
Good Morning,
When updating this morning the server with the updates that were from the web interface: 980, the netdata stats of the proxy stopped working and it is not the first time that happens to me, I leave you log captures to see if you can give me a viable solution, lately shot of the veeam because it is not in production yet but soon this will be unfeasible.
Thanks greetings!!
You could try to reinstall
nethserver-netdata
It seems that by removing the default blocking of all traffic in the web proxy the stats work
This configuration block netdata graph, any idea??
thanks!!
How could I do so that the netdata graphs are not affected by the web proxy configuration, because when I put the web proxy (authenticated) by default it blocks the denial the graphs stop working … and I need that policy by default
hey,
i know its quiet old thread… but did you find a solution? i had same problem
Hi @q16marvin,
best way would be to open a new thread and give us some more information about your config and your problem.
  • What release do you use?
  • Do you use the old server-manager?
Of course you can post the link to the new thread here.
