Hi I’m running into this issue again and the repo isn’t up (not that I expect it to be after all this time) and I’ve tried to compile it myself but I’m not sure how to proceed or where I’d get the src from any help would be great I should have grabbed a copy for backup
I think my issue is that perl-lasso is compiled if you’re using lasso version 2.8 but centos version is 2.5 android doesn’t contain the perl module.
on closer inspection of my dev machine it doesn’t have the required perl modules installed to compile it so I just need to figure out how to update perl that mock uses and it should work
