I need to run an occ command against my nextcloud. I want to update the Forms App to a beta version but Nextcloud is set to stable for app installs. I want to temporarily set:
Do I issue this command using the occ command? And if so, how do I issue the occ command against Nextcloud when using Nethserver? Where is occ located?
https://wiki.nethserver.org/doku.php?id=howto:nextcloud
Regarding using a beta version of an app, I don’t know the proper way. I recall they can be installed manually (downloading the app files to the appropriate directory). I don’t know what the command you posted does (if it affects nextcloud update notification or anything else).
