I am using Sogo and the mail modules a while with sucess. Primary as a local network Mailstore. But now i by a used Print/Copy/fax maschine a HP CM6040mf …
This maschine had a A3 Scanner unit with ADF and this monster had a nice price too
To use the Scanner Unit or Fax functition i need a Mailadress and a internal Mailserver. It will send Emails when it is ready :-), so perfect for my own mailer system.
But it is sad i need a uncryted mail transport from the Printer to my mailserver (last updates installed on the printer …).
It is possibel to aceppt a internal mail uncryted from one IP ?
Option two: relaying https://docs.nethserver.org/en/v7/mail.html?highlight=allow%20relay#special-smtp-access-policies
I’d try to allow relay from the ip address, but remember: this hole will permain until the setting will be put on, so if during night hours someone break in, unplug the lorry, plug it back with the same ip address but with a different device which spam all over the world… nethServer will honor the setting.
