stephdl
(Stéphane de Labrusse)
April 24, 2021, 6:43am
1
I can see in the settings of multiwan that I should be notified by the change of wan NIC. I looked in the mailbox of root but nothing.
Were and how I should be notified when one of my nic is down ?
Another question, if one of my WAN is down, after a count of ping it is disabled, that is fine, is it possible to enable it again after some minutes if the test of ping is true again.
I say this because my two links are not equal, one is fiber the other is 4G
dnutan
(Marc)
April 24, 2021, 8:43am
2
On the old server-manager there was the option to set the e-mail address:
Hello @MarianH ,
Yes, it is:
/var/log/messages
/var/log/firewall.log
You may set it up in GUI and check if a mail was sent in the logfile /var/log/maillog:
[grafik]
firewall’s config db props:
NotifyWan : can be enabled or disabled , if enabled a mail is sent every time a provider changes its own state
NotifyWanFrom : sender address for mails sent if NotifyWAN is set to enabled
NotifyWanTo : recipient address for mails sent if NotifyWAN is set to enabled
On cockpit it seems the same settings are used, and if not set by the user they are gathered from root settings:
notifywanfrom=$(/sbin/e-smith/db configuration getprop root SenderAddress)
notifyto=$(/sbin/e-smith/db configuration getprop root EmailAddress)
You have to have nethserver-lsm package installed, IIRC.
stephdl
April 25, 2021, 6:24am
3
indeed I have a bug to track
[root@firewall ~]# config show firewall
firewall=configuration
CheckIP=8.8.8.8,208.67.222.222
Docker=enabled
ExternalPing=enabled
HairpinNat=disabled
MACValidation=disabled
MACValidationPolicy=drop
MaxNumberPacketLoss=10
MaxPercentPacketLoss=50
NotifyWan=enabled
NotifyWanFrom=
NotifyWanTo=
PingInterval=5
Policy=permissive
SipAlg=enabled
VpnPolicy=strict
WanMode=balance
stephdl
April 25, 2021, 6:46am
4
something weird
Apr 25 08:33:48 firewall postfix/pickup[21889]: C3F7E2483DB: uid=0 from=<-s>
Apr 25 08:33:48 firewall postfix/cleanup[23775]: C3F7E2483DB: message-id=<20210425063348.C3F7E2483DB@firewall.domain.com>
Apr 25 08:33:48 firewall postfix/qmgr[21890]: C3F7E2483DB: from=<-s@firewall.domain.com>, size=749, nrcpt=5 (queue active)
Apr 25 08:33:48 firewall postfix/error[23785]: C3F7E2483DB: to=<-@firewall.domain.com>, orig_to=<->, relay=none, delay=0.01, delays=0.01/0/0/0, dsn=5.1.3, status=bounced (bad address syntax)
Apr 25 08:33:50 firewall postfix/local[23792]: C3F7E2483DB: to=<down@firewall.domain.com>, orig_to=<down>, relay=local, delay=1.4, delays=0.01/0/0/1.4, dsn=5.1.1, status=bounced (unknown user: "down")
Apr 25 08:33:50 firewall postfix/local[23784]: C3F7E2483DB: to=<red1@firewall.domain.com>, orig_to=<red1>, relay=local, delay=1.4, delays=0.01/0/0/1.4, dsn=5.1.1, status=bounced (unknown user: "red1")
Apr 25 08:33:50 firewall postfix/local[23806]: C3F7E2483DB: to=<MultiWAN@firewall.domain.com>, orig_to=<MultiWAN>, relay=local, delay=1.4, delays=0.01/0/0/1.4, dsn=5.1.1, status=bounced (unknown user: "multiwan")
Apr 25 08:33:50 firewall postfix/local[25687]: C3F7E2483DB: to=<state@firewall.domain.com>, orig_to=<state>, relay=local, delay=1.4, delays=0.01/0.02/0/1.4, dsn=5.1.1, status=bounced (unknown user: "state")
Apr 25 08:33:50 firewall postfix/cleanup[23775]: 2AB512483DC: message-id=<20210425063350.2AB512483DC@firewall.domain.com>
Apr 25 08:33:50 firewall postfix/bounce[23791]: C3F7E2483DB: sender non-delivery notification: 2AB512483DC
Apr 25 08:33:50 firewall postfix/qmgr[21890]: 2AB512483DC: from=<>, size=3720, nrcpt=1 (queue active)
Apr 25 08:33:50 firewall postfix/qmgr[21890]: C3F7E2483DB: removed
Apr 25 08:33:50 firewall postfix/error[23785]: 2AB512483DC: to=<-s@firewall.domain.com>, relay=none, delay=0.01, delays=0/0/0/0, dsn=5.1.3, status=bounced (bad address syntax)
Apr 25 08:33:50 firewall postfix/qmgr[21890]: 2AB512483DC: removed
(END)
dnutan
(Marc)
April 25, 2021, 9:00am
5
stephdl:
from=<-s>
(bad address syntax): Does the email address really start with a dash on purpose?
it is looking for a local email account (that does not exist). Is the email address (and related domain) local or remote?
stephdl
April 25, 2021, 10:08am
6
I added my my email address to NotifyWanTo so it should send it, something to check, we have a bug here maybe
stephdl
April 26, 2021, 5:03pm
7
opened 04:43PM - 26 Apr 21 UTC
Steps to reproduce
Create a multiwan server
Enable notification if your link is down
make one of your wan down
you have no notification
Expected behavior
I...
bug
cc @filippo_carletti @edoardo_spadoni What do you think bug or feature
