rothere
(Ruben Rothermel)
1
Would it be possible to have 2 WANs:
- one connected to a dedicated fixed-IP fiber connection to be used mainly by the DMZ servers (mail, http, etc.)
- another coming from a multi-WAN router balancing 3 basic copper WANs for general internet access
and then being able to provide failover when the copper lines go down to use the dedicated fiber line?
Thanks
mrmarkuz
(Markus Neuberger)
2
jgjimenezs
(Jose G Jimenez S )
3
Yes, it is possible by applying some rules in the firewall you will have it activated in a few seconds.
