thorsten
(Thorsten)
July 4, 2018, 10:55am
1
NethServer Version: 7.5
Module: webserver
Sorry, I do not get that from the manuals. Maybe this is up to my technical english, so I kindly ask for some help.
based on my.tld I would like to create some vhosts, such as:
mail.my.tld
www.my.tld
chat.my.tld
dms.my.tld
piwik.my.tld
bib.my.tld
Now I would like to redirect open port requests on my router to Nethsever.
chat.my.tld > mattermost
mail.my.tld -> nethserver-IP\webtop (or sogo)
dms.my.tld -> green-network-IP-running_dms.my.tld
piwik.my.tld -> piwik installed via ftp on nethserver apache
www.my.tld -> drupal installed via ftp on nethserver apache
bib.my.tld -> gren-network-IP-running_calibre.my.tld
Is there good (maybe german manual)
TIA
Thorsten
thorsten
(Thorsten)
July 4, 2018, 11:42am
2
found the first one for reverse proxy … it is an own module within nethserver …
mrmarkuz
(Markus Neuberger)
July 5, 2018, 12:57am
3
For Mattermost you have to set a virtual host via Nethserver web UI:
http://docs.nethserver.org/en/v7/team_chat.html#configuration
Webtop and sogo have an e-smith db prop to set a virtual host/public URL:
http://docs.nethserver.org/en/v7/webtop5.html#change-the-public-url
http://docs.nethserver.org/en/v7/sogo.html#esmith-database
The others should work with reverse proxy.
thorsten
(Thorsten)
July 5, 2018, 11:06am
4
Dear Markus,
for webtop:
Do I need to create an Virtual host first?
Following an Example, I do want to change to say “mail.mydomain.tld” without /webtop. This should work, right?
TIA
Thorsten
mrmarkuz
(Markus Neuberger)
July 5, 2018, 11:18am
5
No, virtual host is not needed.
I didn’t test it but it should work…
thorsten
(Thorsten)
July 5, 2018, 8:49pm
6
Hi Markus,
no, it does not work as expected. Following the procedures described herein:
does not allow to change the host to http://mail.mydomain.tld without /webtop.
mail.mydomain.tld ends up on the default www host.
Is there any other option?
TIA
Thorsten
mrmarkuz
(Markus Neuberger)
July 5, 2018, 9:03pm
7
It should work with a reverse proxy virtual host:
Sorry, doesn’t work, you cannot login
EDIT2:
Workaround via vhost and redirect:
You may create a virtualhost with the virtualhost module:
Create a /var/lib/nethserver/vhost/webtopvhost/index.php
that redirects to the webtop URL:
<?php
header ("location: https://yourdomain.tld/webtop");
Set apache as owner for index.php:
chown apache:apache /var/lib/nethserver/vhost/webtopvhost/index.php
