Congrats to your Nethserver anniversary!
With Nethserver 7.5 mail2 was introduced, do you use nethserver-mail or nethserver-mail2?
I assume you use this patch. Did you edit the /var/lib/getmail/mail@server.cfg directly?
It’s templated so your changes will be overwritten. It would be better to use a custom template.
I think I’m using mail, because mail2 is in the “available” list.
Should have checked my getmail config before I did the update. It’s just a small home server with a few users, so I think I’m going to use the multisorter patch again.
