Multi Domain for SMTP Proxy
NethServer Version: 7.6
Module: SMTP Proxy
Hello
Is The NethServer with module SMTP Proxy(SMTP Filter) support Multi Mail servers(abc.com,xyz.com,…) ?
Thank you
If you set multiple domain in Email Page -> Domain it should work for each domain you’ve set.
How about filter with two domain abc.com, xyz.com ? is it using one filter ?
If they are on one server yes.
