I need to reconfigre the VM Nethserver 8 is running on.
The reason is, I accidentaly made a way to big HDD and afaik there is no way to reduce the size.
So I want to setup another NS8 Node on my Proxmox-Cluster then move all Apps to this node, delete the old Node and be happy ![]()
right now I have the following APPs running:
- Samba
- Grafana
- Netdata
- Nethsecurity Controller
- Nextcloud
- Roundcubemail
- Webserver
I already started to move the Apps to the 2nd Node. Right now I have successfully moved Grafane, Webserver, Nextcloud, Roundcubemail, Netdata
When I tryed to move Nethsecurity Controller ist hung forever at 90% and now I have juste 2 Instances installed, on each Node one.
Trying to move Mail did not work (see Log below), so I deleted Mail from the new Node, itās still working fine on old one.
I did not touch Samba jet, nevertheless I miss Samba on the tab āinstalledā at the softwareCenter.
So what is the save way to move Mail and Samba with all the net folders (and its data) to the new node?
What do I have to do an the Clients side after successfull migration to log on into the domain and get the netfolders right again?
<7>podman-pull-missing ghcr.io/nethserver/mail:1.5.1
<7>extract-ui ghcr.io/nethserver/mail:1.5.1
Extracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/mail6
ui/css/
ui/css/about~31ecd969.98e6c32f.css
ui/css/addresses~31ecd969.80c00828.css
ui/css/app~748942c6.5c1c51bc.css
ui/css/domains~21833f8f.f469460d.css
ui/css/filterBypassRules~31ecd969.b6cdac8b.css
ui/css/filter~31ecd969.2256c011.css
ui/css/mailboxes~31ecd969.1a6b2cb5.css
ui/css/relay~31ecd969.6e78baf2.css
ui/css/settings-general~37ae10c2.8e0cc6ec.css
ui/css/settings-mailboxes~31ecd969.7e9ce8ba.css
ui/css/settings-master-users~af1d5d7a.b183d61f.css
ui/css/settings-queue~99305087.d62eb790.css
ui/css/settings-relay~31ecd969.76a8a5aa.css
ui/i18n/
ui/i18n/de/
ui/i18n/de/translation.json
ui/i18n/en/
ui/i18n/en/translation.json
ui/i18n/es/
ui/i18n/es/translation.json
ui/i18n/eu/
ui/i18n/eu/translation.json
ui/i18n/it/
ui/i18n/it/translation.json
ui/i18n/pt/
ui/i18n/pt/translation.json
ui/i18n/pt_BR/
ui/i18n/pt_BR/translation.json
ui/i18n/uk/
ui/i18n/uk/translation.json
ui/img/
ui/img/module_default_logo.87425d86.png
ui/index.html
ui/js/
ui/js/about~31ecd969.85c110c2.js
ui/js/about~31ecd969.85c110c2.js.map
ui/js/addresses~31ecd969.99ead83b.js
ui/js/addresses~31ecd969.99ead83b.js.map
ui/js/addresses~filter~d939e436.63c63b69.js
ui/js/addresses~filter~d939e436.63c63b69.js.map
ui/js/app~748942c6.78ce0908.js
ui/js/app~748942c6.78ce0908.js.map
ui/js/chunk-vendors~02576867.44c88c8d.js
ui/js/chunk-vendors~02576867.44c88c8d.js.map
ui/js/chunk-vendors~0f485567.8302ab88.js
ui/js/chunk-vendors~0f485567.8302ab88.js.map
ui/js/chunk-vendors~17faf02d.7f68aab6.js
ui/js/chunk-vendors~17faf02d.7f68aab6.js.map
ui/js/chunk-vendors~1d97ff09.290bda9d.js
ui/js/chunk-vendors~1d97ff09.290bda9d.js.map
ui/js/chunk-vendors~205977d4.06c35b15.js
ui/js/chunk-vendors~205977d4.06c35b15.js.map
ui/js/chunk-vendors~2a42e354.0df57e14.js
ui/js/chunk-vendors~2a42e354.0df57e14.js.map
ui/js/chunk-vendors~2aa62147.38204dba.js
ui/js/chunk-vendors~2aa62147.38204dba.js.map
ui/js/chunk-vendors~41d44f25.e7779fa1.js
ui/js/chunk-vendors~41d44f25.e7779fa1.js.map
ui/js/chunk-vendors~46852254.0b6d19c2.js
ui/js/chunk-vendors~46852254.0b6d19c2.js.map
ui/js/chunk-vendors~57473a66.f586d2ed.js
ui/js/chunk-vendors~57473a66.f586d2ed.js.map
ui/js/chunk-vendors~5bb1f863.3efba861.js
ui/js/chunk-vendors~5bb1f863.3efba861.js.map
ui/js/chunk-vendors~5eba3806.b8428291.js
ui/js/chunk-vendors~5eba3806.b8428291.js.map
ui/js/chunk-vendors~690b702c.35a9888d.js
ui/js/chunk-vendors~690b702c.35a9888d.js.map
ui/js/chunk-vendors~7274e1de.f46e1de8.js
ui/js/chunk-vendors~7274e1de.f46e1de8.js.map
ui/js/chunk-vendors~86f6b1bc.93dcf028.js
ui/js/chunk-vendors~86f6b1bc.93dcf028.js.map
ui/js/chunk-vendors~b5906859.deff14e4.js
ui/js/chunk-vendors~b5906859.deff14e4.js.map
ui/js/chunk-vendors~bc21d4b3.68b10b46.js
ui/js/chunk-vendors~bc21d4b3.68b10b46.js.map
ui/js/chunk-vendors~c8728516.dd1ccc58.js
ui/js/chunk-vendors~c8728516.dd1ccc58.js.map
ui/js/chunk-vendors~d2305125.6a99a4ff.js
ui/js/chunk-vendors~d2305125.6a99a4ff.js.map
ui/js/chunk-vendors~d9886323.1a1a66f6.js
ui/js/chunk-vendors~d9886323.1a1a66f6.js.map
ui/js/chunk-vendors~db300d2f.ddb8641c.js
ui/js/chunk-vendors~db300d2f.ddb8641c.js.map
ui/js/chunk-vendors~ec8c427e.5c1734c3.js
ui/js/chunk-vendors~ec8c427e.5c1734c3.js.map
ui/js/chunk-vendors~fdc6512a.81c5c86c.js
ui/js/chunk-vendors~fdc6512a.81c5c86c.js.map
ui/js/domains~21833f8f.d8edabd6.js
ui/js/domains~21833f8f.d8edabd6.js.map
ui/js/filterBypassRules~31ecd969.888d6aea.js
ui/js/filterBypassRules~31ecd969.888d6aea.js.map
ui/js/filter~31ecd969.6289d0aa.js
ui/js/filter~31ecd969.6289d0aa.js.map
ui/js/lang-de-translation-json~3c620948.678ae6ef.js
ui/js/lang-de-translation-json~3c620948.678ae6ef.js.map
ui/js/lang-en-translation-json~9b60384d.a29aea3c.js
ui/js/lang-en-translation-json~9b60384d.a29aea3c.js.map
ui/js/lang-es-translation-json~f7c30340.2b56fad2.js
ui/js/lang-es-translation-json~f7c30340.2b56fad2.js.map
ui/js/lang-eu-translation-json~8ed4c5c2.8d432041.js
ui/js/lang-eu-translation-json~8ed4c5c2.8d432041.js.map
ui/js/lang-it-translation-json~e043826f.a546e7cf.js
ui/js/lang-it-translation-json~e043826f.a546e7cf.js.map
ui/js/lang-pt-translation-json~45d767f3.0b2356b7.js
ui/js/lang-pt-translation-json~45d767f3.0b2356b7.js.map
ui/js/lang-pt_BR-translation-json~eef7148a.564337c2.js
ui/js/lang-pt_BR-translation-json~eef7148a.564337c2.js.map
ui/js/lang-uk-translation-json~14c5171a.48b0dfb6.js
ui/js/lang-uk-translation-json~14c5171a.48b0dfb6.js.map
ui/js/mailboxes~31ecd969.15e10dab.js
ui/js/mailboxes~31ecd969.15e10dab.js.map
ui/js/relay~31ecd969.53f6bfdb.js
ui/js/relay~31ecd969.53f6bfdb.js.map
ui/js/settings-general~37ae10c2.0b56d0ca.js
ui/js/settings-general~37ae10c2.0b56d0ca.js.map
ui/js/settings-mailboxes~31ecd969.fa0a85e1.js
ui/js/settings-mailboxes~31ecd969.fa0a85e1.js.map
ui/js/settings-master-users~af1d5d7a.365f25ba.js
ui/js/settings-master-users~af1d5d7a.365f25ba.js.map
ui/js/settings-queue~99305087.6233f106.js
ui/js/settings-queue~99305087.6233f106.js.map
ui/js/settings-relay~31ecd969.2b2fa5ea.js
ui/js/settings-relay~31ecd969.2b2fa5ea.js.map
ui/js/settings~31ecd969.5838e8ea.js
ui/js/settings~31ecd969.5838e8ea.js.map
ui/metadata.json
ui/shortcuts.json
089cd143a1980e9a97f2150d023cdc412d6ce9a82b537d109933967967c952d2
Assertion failed
File "/var/lib/nethserver/cluster/actions/add-module/50update", line 196, in <module>
agent.assert_exp(create_module_result['exit_code'] == 0) # Ensure create-module is successful
