Hello
looks like a bug …
I am installing a fresh Nethserver 7.5 and let them update to 7.6 NethServer release 7.6.1810 kernel 3.10.0-957.1.3.el7.x86_64.
Than install via Software Center freepbx
Starting https://xxx.xxx.xxx.xxx/freepbx
Building a Freepbx admin.
move over 2 freepbx module update
-Admin > Module Admin
-Starting a online Check
-Download all
-process
result was (testing on 2 VMs)
Reload failed because retrieve_conf encountered an error: 255
exit: 255
exit: 255
Unable to continue. mkdir(): Keine Berechtigung in /var/www/html/freepbx/admin/modules/digium_phones/functions.inc.php on line 50
#0 [internal function]: Whoops\Run->handleError(2, ‘mkdir(): Keine …’, ‘/var/www/html/f…’, 50, Array)
#1 /var/www/html/freepbx/admin/modules/digium_phones/functions.inc.php(50): mkdir(’/var/www/html/d…’, 493, true)
#2 /var/www/html/freepbx/admin/modules/digium_phones/classes/digium_phones.php(2019): digium_phones_get_http_path()
#3 /var/www/html/freepbx/admin/modules/digium_phones/classes/digium_phones.php(56): digium_phones->read_customapps()
#4 /var/www/html/freepbx/admin/modules/digium_phones/classes/digium_phones.php(36): digium_phones->load()
#5 /var/www/html/freepbx/admin/modules/digium_phones/functions.inc.php(327): digium_phones->digium_phones()
#6 /var/lib/asterisk/bin/retrieve_conf(585): digium_phones_conf->digium_phones_conf()
#7 {main}
Sorry german installation "Keine Berechtigung " means no rights …
Looks like update will buil a directory and there a no rights to build it.
But the massage is a littel bit short to know witch one .
Looks like the bug that markus [mrmarkuz] is working on in August 17.
Mutch more problems with rigths. I try some first update for freepbx modules. I didnt use digium_phones abd othe critical modules.
If i try modules again a lot of erros are there
ll /etc/asterisk:
short snip
-rw-rw-r-- 1 asterisk asterisk 91 Dec 17 11:25 cdr_adaptive_odbc.conf
-rw-r–r-- 1 root root 0 Dec 17 11:27 cdr.conf
lrwxrwxrwx 1 root root 52 Dec 17 11:27 cel.conf -> /var/www/html/freepbx/admin/modules/cel/etc/cel.conf
next i will try to set this files to asterisk.asterisk
Now Upgrade is running …
but i don´t try again to install
XMPP
digium_phones
digium_config
more later
Thx Axel
