Hi - I’ve installed NS 7 rc3, vhosts, samba AD, the nethserver-php-scl and Nextcloud and all is working as intended. Yay.
I’ve moved from Zentyal to NS, and I had my Nextcloud installed at cloud.domain.name. In Nethserver, it is at servername.domain.name/nextcloud. Rather than change all the settings on my client machines, I would rather have nextcloud served from the cloud.domain.name url.
I added a cloud.domain.name/cloud vhost, put a system link from /var/lib/nethserver/vhosts/cloud to the nextcloud installation directory, added the url to the permitted hosts, modified the vhost config for apache to allow following system links, and it worked. But the vhost config gets updated and it stops working. To be expected.
So I am wondering what the best way to get my nextcloud installation served from cloud.domain.name is. Can I make a custom template for that vhost, or for nextcloud configuration? Or would it just be easier to install Nextcloud into the cloud vhost folder?
in fact a custom template should be done with a db property specific to your vhost for activating your followSymlink if needed. @davidep my idea to add more apache directives makes senses
In this case you will lost all neth customisations, you will are on your own to integrate Nethserver’s users to nexcloud.
The file paths for the httpd example need to be updated though - I’m guessing it still has the old file paths. I had to put the custom configuration in
/etc/e-smith/templates-custom/httpd/vhost-extra/30directory20options
not the equivalent in
