gerald_FS
(Gerald)
1
Hello!
For the birthday I got a new AV center, a horny part.
Marantz NR1606
Now I will gladly my music collection on the server is access to it, I would like to MiniDLNA install.
Is there something to consider, possibly known problems?
I will follow the instructions below:
https://jeff.thatonedomain.com/readymedia-on-centos-7/
Https://rtfmp.com/2015/09/27/how-i-install-minidlna-on-centos-7-1-and-stream-local-media-to-chromecast/
Are there better alternatives?
giacomo
(Giacomo Sanchietti)
2
It should work, but rather than disable the firewall you should open these ports: ssdp (1900/udp) and trivnet1 (8200/tcp)
config set minildna service status enabled access green TCPPorts 8200 UDPPorts 1900
signal-event firewall-adjust
gerald_FS
(Gerald)
3
many many thanks!
I have now done this guide and everything is running perfectly!
