a quick question. What would currently be the way to go if I need a simpel small footprint server/gateway NS7 machine with 2 x RJ45. I know about the PI solutions with an extra USB->RJ45 but the transfer rate of the USB bus is already limited. Likely an ARM device?
The major vendors (Dell, HPE, Lenovo) sell a variety of mini-PCs in 1L size or smaller (the ThinkCentre M75n is .35L), but it looks like most of them only have one network interface. USB’s always an option, of course. But they do have video adapters, so no need for a serial console.
Ok, found a neat little device that is ARM based. Just curious what you guys think about the feasibility of putting it up to the task as a home NS server/gateway.
Hello everyone, for example, I am happy with these mini PCs.
HP ELITEDESK 705 G3 PC (Certified Refurbished) AMD QUAD CORE A6-9500E - SVGA RADEON R5 - 8GB RAM - 128GB SATA SSD -
4x USB 3.0 - 2x USB 2.0 - LAN - AUDIO JACK - VGA - DISPLAY PORT -
I easily manage 2 wan and everything you need and it is fully compatible with nethserver
Have a look at the HUNSN Fanless Mini-PC range. There’s a variety of CPU configs and they are nicely built. Recently, the 2 x LAN, 4 x USB, 2 x HDMI with a Celeron and Windows license was cheaper than a Raspberry Pi!
Unfortunately the link we bought from at Amazon a month ago is dead and I can’t seem to find any more of that model for sale - perhaps was an older or limited model clearance. This was the one:
Was impressed by the build etc. Maybe your google ‘foo’ will have better luck finding similar.
