Released!
You’ll find version 1.1.6 from the default repository in a few hours.
Released!
Ok perfect ![]()
Hi i just update to 1.1.6
I receive the popup that update was completed, but this is what i see when i open the istance, still in this state:
This is the log of instance:
PODMAN_SYSTEMD_UNIT=nextcloud.service)
2024-04-05T09:42:01+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:01.21983666 +0200 CEST m=+0.179667902 container start 848583d712a263c6efb0b876cc28276ecd5a12ee02325ad54902765e225790d7 (image=localhost/podman-pause:4.3.1-0, name=54695bfc9b3c-infra, pod_id=54695bfc9b3c719f9a91741405734d28711589ba79732c1862d4f84c16a4247a, PODMAN_SYSTEMD_UNIT=nextcloud.service, io.buildah.version=1.28.2)
2024-04-05T09:42:01+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:01.219886431 +0200 CEST m=+0.179717674 pod start 54695bfc9b3c719f9a91741405734d28711589ba79732c1862d4f84c16a4247a (image=, name=nextcloud)
2024-04-05T09:42:01+02:00 [1:nextcloud2:podman] 54695bfc9b3c719f9a91741405734d28711589ba79732c1862d4f84c16a4247a
2024-04-05T09:42:01+02:00 [1:nextcloud2:systemd] Started nextcloud.service - Podman nextcloud.service.
2024-04-05T09:42:01+02:00 [1:nextcloud2:agent@nextcloud2] Running /home/nextcloud2/.config/update-module.d/50bind_user_domain...
2024-04-05T09:42:01+02:00 [1:nextcloud2:agent@nextcloud2] task/module/nextcloud2/e581827d-0fec-4cb8-a709-1d30874541da: update-module/95cleanup_images is starting
2024-04-05T09:42:03+02:00 [1:nextcloud2:agent@nextcloud2] Untagged: docker.io/library/mariadb:10.6.16
2024-04-05T09:42:03+02:00 [1:nextcloud2:agent@nextcloud2] Deleted: 10fbb70b8165849c093d7dfae33673a4ea4397cfd03ac26a733fd0118c76c8e6
2024-04-05T09:42:03+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:03.286983394 +0200 CEST m=+1.850736904 image untag 10fbb70b8165849c093d7dfae33673a4ea4397cfd03ac26a733fd0118c76c8e6 docker.io/library/mariadb:10.6.16
2024-04-05T09:42:03+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:01.45886192 +0200 CEST m=+0.022615446 image remove 10fbb70b8165849c093d7dfae33673a4ea4397cfd03ac26a733fd0118c76c8e6 docker.io/library/mariadb:10.6.16
2024-04-05T09:42:07+02:00 [1:nextcloud2:agent@nextcloud2] Untagged: ghcr.io/nethserver/nextcloud-app:1.1.5
2024-04-05T09:42:07+02:00 [1:nextcloud2:agent@nextcloud2] Deleted: b342d85ff6414729025b5d3b82ede7ac5a49f4d6a12a39d2270f174f93f09d26
2024-04-05T09:42:07+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:07.254955154 +0200 CEST m=+3.962597716 image untag b342d85ff6414729025b5d3b82ede7ac5a49f4d6a12a39d2270f174f93f09d26 ghcr.io/nethserver/nextcloud-app:1.1.5
2024-04-05T09:42:07+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:03.310879436 +0200 CEST m=+0.018522005 image remove b342d85ff6414729025b5d3b82ede7ac5a49f4d6a12a39d2270f174f93f09d26 ghcr.io/nethserver/nextcloud-app:1.1.5
2024-04-05T09:42:07+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:07.720856232 +0200 CEST m=+0.459409861 image untag 2b70e4aaac6b5370bf3a556f5e13156692351696dd5d7c5530d117aa21772748 docker.io/library/nginx:1.25.3-alpine
2024-04-05T09:42:07+02:00 [1:nextcloud2:agent@nextcloud2] task/module/nextcloud2/e581827d-0fec-4cb8-a709-1d30874541da: action "update-module" status is "completed" (0) at step 95cleanup_images
2024-04-05T09:42:07+02:00 [1:nextcloud2:agent@nextcloud2] Untagged: docker.io/library/nginx:1.25.3-alpine
2024-04-05T09:42:07+02:00 [1:nextcloud2:agent@nextcloud2] Deleted: 2b70e4aaac6b5370bf3a556f5e13156692351696dd5d7c5530d117aa21772748
2024-04-05T09:42:07+02:00 [1:nextcloud2:podman] 2024-04-05 09:42:07.281662598 +0200 CEST m=+0.020216226 image remove 2b70e4aaac6b5370bf3a556f5e13156692351696dd5d7c5530d117aa21772748 docker.io/library/nginx:1.25.3-alpine
Update:
After shutdown and boot up again now dashboard loaded elements properly, but in ns7 give the error can’t retrive apps to migrate, i see that wireguard on ns8 is not up
This is the error on ns7:
Update:
Problem is wireguard can connect because publick key and private key not maching, so i disconnect the cluster from ns8 migration tool and rejoin another time now is syncing nextcloud the instance of nextcloud now is rename to “nextcloud3”.
I update if with this new image version of podman container it works the migration.
Migration process completed it works!
Hi everybody
I noticed when i log with user account in top right corner i see this:
Another thing if i click on this button:
How does the Nextcloud users page look like? Are the real user names there?
I assume you’re using AD?
I think it’s because of the migration because I don’t see these UUIDs in my Nextcloud on NS8.
Maybe relevant:
Hi @mrmarkuz
This is the home page i think after “Buon Pomeriggio” should be the username but not in this case.
I meant to check the Nextcloud users in the UI:
or on CLI:
runagent -m nextcloud1 occ user:list
Are the real names there?
Maybe you just need to adapt the LDAP settings in Nextcloud to show the right LDAP field.
There’s a working LDAP editor for NS8 called LAM, see GitHub - stephdl/ns8-lam
This way you can easily check LDAP fields and values.
Ok, so the link is correct but the page isn’t working?
Could you please show the content of the route?
i don’t have users if i click on Avatar of Admin account like your screenshot:
On CLI i have only admin:
mbianchi@ns01:~$ sudo runagent -m nextcloud3 occ user:list
- admin: admin
HTTP Routes content of “Nextcloud3”
You need to login with the internal Nextcloud admin, the default admin password is Nethesis,1234 if you didn’t change it.
To reset the admin password:
runagent -m nextcloud3 occ user:resetpassword admin
Did you already try to reconfigure the domain in NS8 Nextcloud app settings and “Save”. Hopefully it resets the LDAP connection and solves the issue.
Maybe a similar issue?
I see that “nextcloud” app the let’s encrypt button slide is not enable:
Please enable letsencrypt and save the settings again with right domain.
Hi @mrmarkuz
Already did
Update:
While I was replying here, i tried again and now the users is detected correctly, without having done anything.
