Does somebody know if it’s possible to migrate users from zentyal (3.x) to neth, including usernames and PW?
Maybe from a config backup?
Hi Pascal and welcome,
I do not know if it is possible to import users.
You can try to join the Z 3.x server as a slave to NS master and then see if the users are migrated. (or manual via export of users and import but I do not know if it is also possible)
Maybe somebody with more LDAP knowledge can tell you.
Best regards
Bogdan
If zentyal is configured as slave it will delete all users/groups.
So some kind of ldap export import would be helpful. But my ldap skills are limited.
It seems to that ldap tree is wery different, you could check it with phpldapadmin , i wrote about it installation or use Ldapadmin for Win or Apache directory studio for linux or Mac. I suppose that you could try some export import above this utils . AFIK there is option in NS that you could import users from CSV file;)
nice thank’s. I’ll try it out and report if it’s working.
NS can be a DC in a NT style, so I guess that zentyal would not connect to it as it expects a AD DC.
Could you export user on csv file? If it’s possibile then you can import them on NethServer
I’ll check it out, but what about the passwords I guess they are hashed. Is it possible to import the hashed passwords?
I don’t think so
@Pascal_Michard as i have already said you could do it from LDAP , export from Zentyal edit for impoting password section only for users
OK, thanks. I’ll try.
Give some export string for making script, it could be very usefull, maybe could integrate to WEB
https://wiki.samba.org/index.php/Samba_Classic_Upgrade_(NT4-style_domain_to_AD)
"The migration from an NT4-style domain to Active Directory is one way! This means that once your clients contact your migrated AD Domain Controller, they will never be able to access the NT4-style domain again - even if you roll back your changes!It’s highly recommended, that before you do the migration, you should test the upgrade process in a separate network from your production! This enables you to avoid unnecessary downtime through unpredictable problems and it won’t have any effect on your existing network
