Hi everyone, I currently have around 50 Windows 10 computers all joined to a Samba4 domain built on CentOS. Is there a way to migrate roles to Nethserver without creating a domain from scratch and rejoining all computers to the new server? Has anyone already performed this procedure? Thank you
And welcome to the NethServer community.
There IS a way to migrate your Samba installation, as both use the same underlying Samba AD (Compatible 2012R2), it’s just not officially supported, but should work.
Method:
- Join NethServer to the Samba AD domain.
- Promote NethServer using Windows Tools and verify.
- Remove the Centos based Samba Server from the AD domain.
- Your user accounts and AD Domain should be intact on NethServer. The Domain SID should be the same.
- You will need to adapt the AD DNS to make sure it points to the new AD using either MS RSat tools or PHPLDAPAdmin.
- Check your AD and verify clients can log in.
- You still need to manually move over the user home contents.
- Create other shares as needed on NethServer, and move over the contents (rsync).
- Set permissions on shares / userhomes as needed.
Note: The above is an incomplete list, more may be needed, eg. NethServer e-smith SET commands…
Double check everything!
And as always in such a situation: Good Luck!
This / similiar tasks have been done and partially documented here in this forum, but each case is a one off with a lot of differences between each one,…
Thanks Andy for your reply.
Should I add the NethServer to the Centos domain as a member via the web gui or should I follow this guide?
howto:add_ns7_samba_domain_controller_to_existing_active_directory [NethServer Wiki]
I’d try the WebGUI first, since that post, there’s been quite a few improvements.
If not, you still have the post method.
It could be that the GUI only adds NethServer as a member, not a dc, then the post method would be needed.
Your mileage may vary…
As usual, backup your steps, or if running virtual, make snapshots!
