Hi All
@jaywalker:
I’ll assume a typical local SME setup here.
This is true in the fact that there is no supported migration.
However, it is possible to do such a migration and it would work…
An AD running on NS7 can be migrated (supported!), and clients do not need to be modified, if IP, DNS and AD names are conform (especially for network drives).
For starters, the Samba AD used in NethServer 7 is fully MS Windows AD 2012 compatible.
This would allow joining eg a Windows Server as another AD controller.
This could also be another Samba server. And one could be promoted, the other demoted / removed…
Typical MS method.
A second method: Linux / Samba doesn’t use a Registry like MS, the info is all in text files somewhere.
The key part of AD is the SID, this CAN be copied!
If IP, Hostname, FQDN, AD-FQDN and SID correspond, you will have a successful migration.
A few words of caution:
Before doing anything, a working backup is a must!
None of the above should be used / attempted on a live Samba AD.
Using a Hypervisor like Proxmox can make the whole effort easier and faster.
Check and double check all used FQDNs, IPs, SIDs and folder permissions!
A rule of thumb from my side:
Above twenty users, I would migrate and save work with clients.
Less than 10, I would attempt a clean new installation.
Those in between would depend on the exact situation…
@laidback_01
The VPN module mentionned by @oneitonitram comes from the fact that his NS7 AD is in a hosted environment, and NS8 (At a different hoster) can’t contact that NS7 to migrate…
A bad choice to have the AD in the cloud, with no real access option.
It has no consequence for any normal, local setup.
