Metrics dashboard not available
NethServer Version: latest udates
Module: latest updates
Anybody else having issues accessing the default metric dahsboard please?
I updated metrics on 2 nodes earlier to 1.2.5 and it’s fine on both nodes I have it enabled on.
Does it help to disable/reenable the Grafana dashboard in the UI?
Does it work in another browser? (cache issues)
Let’s check the configuration:
api-cli run module/metrics1/get-configuration
[root@srv01 ~]# api-cli run module/metrics1/get-configuration
{“grafana_path”: “grafana”, “mail_from”: “alertmanager@xxx.com”, “mail_to”: [“support@xxx.com”], “prometheus_path”: “”}
-2026-03-31T16:07:12+02:00 [1:metrics1:agent@metrics1] task/module/metrics1/a1d0a9d5-f9cc-4173-9f34-bd24fe82ac61: get-configuration/20read is starting
2026-03-31T16:07:13+02:00 [1:metrics1:agent@metrics1] task/module/metrics1/a1d0a9d5-f9cc-4173-9f34-bd24fe82ac61: action “get-configuration” status is “completed” (0) at step validate-output.json
No, I disabled and enabled is several times
No, different browser same issue
The dashboard link (hhtps://xxx.com/grafana) leads to
Not Found
The requested URL was not found on this server.
Apache/2.4.58 (Ubuntu) Server at xxx.com Port 80
Maybe xxx.com points to some webapp? I suspect the apache of the lamp app.
Does it work using the node IP?
Grafana should be reachable at
https://<node_fqdn_or_ip>/grafana
Find webapps using xxx.com in traefik:
grep -iR xxx.com /home/traefik1/.config/state/configs/
You are on to something. I will check laten when I can access. Thx!
It is, thanks for that. I installed LAMP and deployed vvveb, the node FQDN is srv01.xxx.xom and the LAMP deployment FQDN is xxx.com (set by the LAPM instance config).
So I wonder how the dashboard link works, for before LAMP deployment I could reach it.
The link just takes the hostname/IP from the browser, see ns8-core/core/ui/src/views/settings/SettingsMetrics.vue at 695043a8a9311906803dfd815cae84e95686d816 · NethServer/ns8-core · GitHub
So if you are accessing the cluster admin via xxx.com/cluster-admin, the dashboard link to Grafana dashboard is xxx.com/grafana
Actually, that is exactly the problem. I can access /cluster-admin, but not /grafana
It could well be I misused DNS A record to point to xxx.com, whilst the node FQDN is node.xxx.com
