MeshCentral fresh Install: WARNUNG: Unable to find mongodump, MongoDB database auto-backup will not be performed
NethServer Version: 7.9.2009
Module: MeshCentral
@mrmarkuz
Hi Markus
On a freshly installed NethServer as VM on Proxmox inside a Hetzner Cloud, I’m getting the following error on first log-in on MeshCentral. The server is completly up-to date as from NOW !
MeshCentral is installed as virtualhost with working LE SSL certs. NethServer has only one NIC, Internet / Firewalling is done with an OPNsense. LE is done by NethServer.
During the install of MeshCentral (done with SSH from remote) no issues were reported…
The Problem?
WARNUNG: Unable to find mongodump, MongoDB database auto-backup will not be performed.
How can this be fixed? (I suppose installing mongodump, but which version and how?).
I didn’t get this error the last time I installed MeshCentral (a few months ago).
Thanks iA!
I need to check, maybe something changed in newer versions of meshcentral…
i see a similar problem on one of my vms.
and yes its with meshcentral latest.
@pike
I installed last night, I still don’t see any Backup (yet).
It could be OK, but I’ll have to wait until tomorroy to verify…
At the moment, /var/lib/nethserver/meshcentral/backup is still empty…
You may create a symlink in /usr/bin to /opt/rh/rh-mongodb36/root/usr/bin/mongodump, this way mongodump is found by meshcentral and the message should disappear.
I’m going to add the symlink in the next update.
@mrmarkuz
Might be a bit difficult:
seems a “rh” is missing in /opt/rh/rh-mongodb36/root/usr/bin/mongodump
But if the path is corrected, your solution works!
Sorry, was a bit to early. the error still remains.
Thanks!
Nethserver-meshcentral depends on rh-mongodb36, so it should be installed…
[root@testserver2 ~]# yum deplist nethserver-meshcentral
  dependency: rh-mongodb36
   provider: rh-mongodb36.x86_64 3.0-18.el7.sc1
Yes, you are right, I’ll correct my post…
Seems to be all there…
A reboot was needed - i suspected as much…
You know the old german saying:
“Reboot tut immer gut”…
freely translated into english:
“A reboot always does a lot of good”…
:slight_smile:
The error message is now gone.
Maybe a restart of the services would have been enough…
like this
:slight_smile:
more precisely:
ln -s /opt/rh/rh-mongodb36/root/usr/bin/mongodump /usr/bin/mongodump
:slight_smile:
