Hopefully this can be implemented into Nethserver 7.9
We really need a more up-to-date version of MariaDB.
Notable changes in MariaDB 10.6.5
InnoDB
- Linux after kernel version 5.10 has a io-uring regression causing a write to storage to be lost, or not acknowledged. As such innodb_use_native_aio will default to 0 (off) until 5.16. If innodb_use_native_aio is enabled in your configuration, a warning will be logged, however it will continue with the io-uring enabled, potentially resulting in a hang, or an assertion later. The long term support kernel 5.14.14 we haven’t observed failures, and 5.15.0-rc7 failures have been observed, though less frequently. If you have innodb_use_native_aio explicitly enabled, and are using watch out for a lack of InnoDB updates followed by a 10 minute timeout. See MDEV-26674for details.
ALTER TABLE…IMPORT TABLESPACE
fixes (MDEV-18543, MDEV-20931, MDEV-26131, MDEV-26621) -
innodb_undo_log_truncate
fixes (MDEV-26445, MDEV-26450, MDEV-26672, MDEV-26864) - Page I/O performance fixes (MDEV-25215, MDEV-26547, MDEV-26626, MDEV-26819)
- Replication timeouts with
XA PREPARE
(MDEV-26682) - Improved DDL and data dictionary (MDEV-25919)
- Performance fixes (MDEV-26356, MDEV-26467, MDEV-26826)
Replication
- Memory hogging on slave by ROW event applier is eliminated (MDEV-26712)
mysql --binary-mode
now properly handles\\0
in data (MDEV-25444) - Fixes race condition between
SHOW BINARY LOGS
andRESET MASTER
(MDEV-20215)
Packaging & Misc
- Session tracking flag in OK_PACKET (MDEV-26868)
- Some views force server (and mysqldump) to generate invalid SQL for their definitions (MDEV-26299)
