After a clean reinstall, I’m not convinced I was seeing what I thought I was seeing. Disregard.
Don’t know what happened, but can you find something at the logs? It should be
/var/log/nethserver-install.log
To make your network running again you should read this thread:
There probably would have been, but I wiped the disks and reinstalled (it was a fresh install with no data, so nothing was lost). On the reinstall, I didn’t touch the network settings in the installer, waiting until the system booted to adjust them through the web GUI. And aside from the minor GUI bug I reported in a different thread, it’s working fine.
There is a known issue with anaconda not doing what is expected.
see Honor static IP configuration from interactive ISO installer and The IP set during a clean installation is changed after the first reboot and IP 192.168.1.1 after the installation
