hmm, nothing what makes sense to meâŠ
May 13 11:20:02 sbs rspamd[3087]: <fd6de5>; csession; rspamd_message_parse: loaded message; id: <topic/9842/63391@community.nethserver.org>; queue-id: <undef>; size: 8190; checksum: <7f88c09f4a0a498e50c7446d6c8fa73f>
May 13 11:20:02 sbs rspamd[3087]: <fd6de5>; csession; fuzzy_generate_commands: <topic/9842/63391@community.nethserver.org>, part is shorter than 1000 bytes: 810 (405 * 2.00 bytes), skip fuzzy check
May 13 11:20:02 sbs rspamd[3087]: <fd6de5>; csession; fuzzy_generate_commands: <topic/9842/63391@community.nethserver.org>, part is shorter than 1000 bytes: 810 (405 * 2.00 bytes), use direct hash
May 13 11:20:03 sbs rspamd[3087]: <fd6de5>; lua; antivirus.lua:480: failed to scan: IO read error while trying to read data: Connection reset by peer
May 13 11:20:06 sbs rspamd[3087]: <fd6de5>; csession; fuzzy_check_timer_callback: got IO timeout with server fuzzy.rspamd.com(88.99.142.95), after 1 retransmits
May 13 11:20:06 sbs rspamd[3087]: <fd6de5>; csession; bayes_classify: skip classification as spam class has not enough learns: 63, 200 required
May 13 11:20:06 sbs rspamd[3087]: <fd6de5>; lua; greylist.lua:255: Score too low - skip greylisting
May 13 11:20:06 sbs rspamd[3087]: <fd6de5>; csession; rspamd_task_write_log: id: <topic/9842/63391@community.nethserver.org>, ip: 212.227.17.5, from: <nethserverdiscourse@gmail.com>, (default: F (no action): [0.08/15.00]
[MV_CASE(0.50){},R_DKIM_ALLOW(-0.20){discoursehosting.com;},MAILLIST(-0.10){generic;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},HAS_LIST_UNSUB(-0.01){},MX_GOOD(-0.01){alt1.gmail-smtp-in.l.google.com;},ASN(0.00){asn:8560,
ipnet:212.227.0.0/16, country:DE;},CLAMAV_FAIL(0.00){failed to scan;},DKIM_TRACE(0.00){discoursehosting.com:+;},DMARC_NA(0.00){nethserver.org;},FREEMAIL_ENVFROM(0.00){gmail.com;},FREEMAIL_ENVRCPT(0.00){gmx.de;},FREEMAIL_REPLYTO(0.00)
{gmail.com;},FREEMAIL_TO(0.00){gmx.de;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){alessio.fattorini@nethserver.org;nethserverdiscourse@gmail.com;},HAS_REPLYTO(0.00)
{nethserver.discourse+09deb1a942c17b43fee8079b7f088437@gmail.com;},PREVIOUSLY_DELIVERED(0.00){xxx@gmx.de;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_ONE(0.00){1;},RCVD_IN_DNSWL_LOW(0.00){5.17.227.212.list.dnswl.org :
127.0.3.1;},RCVD_TLS_ALL(0.00){},REPLYTO_DOM_NEQ_FROM_DOM(0.00){},R_SPF_SOFTFAIL(0.00){~all;},TAGGED_FROM(0.00){verp-42a68aaccae7db1cf270f7e349105b90;},TO_DN_NONE(0.00){}]), len: 8190, time: 4224.033ms real, 14.803ms virtual, dns req:
35, digest: <7f88c09f4a0a498e50c7446d6c8fa73f>, mime_rcpts: <xxx@gmx.de>, file: stdin
May 13 11:20:06 sbs rspamd[3087]: <fd6de5>; csession; rspamd_protocol_http_reply: regexp statistics: 86 pcre regexps scanned, 3 regexps matched, 172 regexps total, 10 regexps cached, 19.06k bytes scanned using pcre, 19.06k bytes scanned total
May 13 11:20:06 sbs dovecot: lda(xxx@xxxxxxx.lan): sieve: msgid=<topic/9842/63391@community.nethserver.org>: stored mail into mailbox 'INBOX'
May 13 11:20:06 sbs getmail: msg 1/1 (8361 bytes) msgid 0MbALX-1eytPI0uYl-00KhB0 from <nethserver.discourse+verp-42a68aaccae7db1cf270f7e349105b90@gmail.com> delivered to MDA_external command dovecot-lda (), deleted
May 13 11:20:56 sbs rspamd[3087]: <3d89ch>; lua; neural.lua:813: check ANN tRFANN41F3D208416AF2B1260
May 13 11:20:56 sbs rspamd[3087]: <3d89ch>; lua; neural.lua:825: no need to learn ANN tRFANN41F3D208416AF2B1260 0 learn vectors (1000 required)
May 13 11:21:56 sbs rspamd[3087]: <3d89ch>; lua; neural.lua:813: check ANN tRFANN41F3D208416AF2B1260
May 13 11:21:56 sbs rspamd[3087]: <3d89ch>; lua; neural.lua:825: no need to learn ANN tRFANN41F3D208416AF2B1260 0 learn vectors (1000 required)
