hazarder
(Tomaz Gajser)
March 4, 2026, 4:57pm
1
Hi people, lovers oh Nethserver!
I am using Nethserver 8 with a few server installations. Mostly as “mail” server, also “nextcloud” and “lamp“.
All I can say - I love it - as it is all I need. All in the box! But some minor tweaks were also usefull and that is why I am writing…
Some people have warned me, suggested, that it would be a good point to have a WARNING for incoming mail:
something like red sign - “Be aware - this is external mail!“ I have seen it in the body of messages, as html can be inserted there.
This should be inserted just for external mails, not local sent for local domain → local domain.
I have investigated some points, Altermine and Milter are suggested.
Could it be possible, to integrate somethink like this into Nethserver 8 - Mail module?
Thanks!
LayLow
(LayLow)
March 4, 2026, 5:53pm
2
So all non local inbound email should have a policy based header?
Please note that internally forwarded non-local domain emails with clickable URL’s will still be clickable without a warning.
So the question is, are you trying to hide staff incompetance/mistakes or solve a technical issue?
Don;t get me wrong, I see these ‘warnings’ all over the place, but without policy and training they are worthless, which they are btw legally.
mrmarkuz
(Markus Neuberger)
March 5, 2026, 7:50am
3
Adding such notification breaks the mail signatures, check following thread:
I’m sorry but we can’t implement mail disclaimer on the server side to avoid breaking digital mail signatures. As alternative configure the disclaimer in the mail client. If you use the Webtop groupware you can look at Mailcards: WebTop groupware — NS8 documentation .
Edit: if someone wants to try, Rspamd’s developer published a custom script that adds a footer at pre-filter stage: footer.lua · GitHub . Disclaimer - I don’t known if/how it works.
Additionally, to really check if a mail comes from external/internal you’ll need a mail gateway as you can’t rely on sender addresses because of spoofing.
