Logs - check problems
Hello,
in which logs to check problems with DHCP and static routing?
You may have a look in /var/log/messages but…may I ask what’s the problem?
Sometimes static routing does not work or printers do not get an IP address
You may check which device got an IP via DHCP with:
cat /var/log/messages | grep dhcp
What does not work, can you explain?
With “cat /var/log/messages | grep dhcp” you can see if your printer gets an IP address. As a workaround you may give your printer a static IP.
Ok, unfortunately I do not know which ones have mistakes. I’ve already tried to assign static ip, sometimes it did not help
Did you check your network hardware? If static IPs do only work sometimes the error may be there…
If you want this resolved it might be a good idea to give some more info on how your network looks like. Do you use multiple subnets? (you talk about static routes)
How can a static IP not be issued to a printer? If it is a networked printer you can always assign it a static IP address. Does your DHCP sope overlap the static IP you assign to your printer? Or is it a permanent IP address assigned in DHCP?
192.168.203.0 /24 LAN
172.16.0.0 / OpenVPN
Network 10.200.20.0 /24 --> 192.168.203.254 – interface br0 - Static route (sometimes not working)
I use permanet Ip adress assigned in DHCP , my DHCP can overlap the static ip to printer in some cases.
How to distinguish between logs and errors?
Jan 25 15:26:57 neth kernel: IPv4: host 192.168.203.144/if5 ignores redirects for 10.200.20.11 to 192.168.203.254
What are you trying to do that gives an error? Print from openvpn? Is the network 10.200.20.0/24 connected to br0?
Could you please post the output of ip addr and ip route?
Usually you have something like “error”, “warning” or “fail” in bad log entries.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP qlen 1000
link/ether 00:e0:4c:0f:67:86 brd ff:ff:ff:ff:ff:ff
inet6 fe80::2e0:4cff:fe0f:6786/64 scope link
3: enp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc prio state UP qlen 1000
link/ether 6c:62:6d:b2:e8:38 brd ff:ff:ff:ff:ff:ff
inet 78.11.48.28/24 brd 78.11.48.255 scope global enp2s0
inet6 fe80::6e62:6dff:feb2:e838/64 scope link
4: enp4s2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc prio state UNKNOWN qlen 1000
link/ether 00:e0:4c:4d:37:5a brd ff:ff:ff:ff:ff:ff
inet 192.168.1.4/24 brd 192.168.1.255 scope global enp4s2
inet6 fe80::2e0:4cff:fe4d:375a/64 scope link
5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP qlen 1000
inet 192.168.203.1/24 brd 192.168.203.255 scope global br0
6: vb-nsdc@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP qlen 1000
link/ether 4a:90:6b:7a:52:38 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::4890:6bff:fe7a:5238/64 scope link
7: tunrw: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN qlen 100
link/none
inet 172.16.0.1 peer 172.16.0.2/32 scope global tunrw
inet6 fe80::653e:3b23:a9c:60f4/64 scope link flags 800
10.200.20.0/24 via 192.168.203.254 dev br0
78.11.48.0/24 dev enp2s0 proto kernel scope link src 78.11.48.28
78.11.48.25 dev enp2s0 scope link src 78.11.48.28
169.254.0.0/16 dev enp2s0 scope link metric 1003
169.254.0.0/16 dev enp4s2 scope link metric 1004
169.254.0.0/16 dev br0 scope link metric 1005
172.16.0.0/24 via 172.16.0.2 dev tunrw
172.16.0.2 dev tunrw proto kernel scope link src 172.16.0.1
192.168.1.0/24 dev enp4s2 proto kernel scope link src 192.168.1.4
192.168.1.1 dev enp4s2 scope link src 192.168.1.4
192.168.203.0/24 dev br0 proto kernel scope link src 192.168.203.1
Everything works fine 1-2 days, then static routing stops working. Network 10.200.20.0/24 is connected to some Fortigate device and has IP 192.168.203.254. Then I change the nethserver to TD-W8970 tp-link router and again the network works correctly.
Strange. This may happen If the FortiGate got its LAN IP via DHCP from the TP-Link and not from NethServer.
Is the static route “10.200.20.0/24 via 192.168.203.254 dev br0” still in the routing table (ip route) when the error occurs? Can you ping the FortiGate?
You don’t have a default gateway on NethServer?
I don’t get how you connect to the internet…please help me.
Is the TD-W8970 tp-link configured exactly like NethServer (same IPs, static routes…)?
624/5000
Nethserver is connected to two WAN links.
WAN1 - interface 78.11.48.28 - gateway - 78.11.48.25
WAN2 - interface 192.168.1.4 - gateway adsl router -192.168.1.1
DHCP range on Nethserver is 192.168.203.3 - 192.168.203.253
Is the static route “10.200.20.0/24 via 192.168.203.254 dev br0” still in the routing table (ip route) when the error occurs? Can you ping the FortiGate? - I will check this
You do not have a default gateway on NethServer? - I understand that it should be 192.168.203.1 on the br0 interface?
TD-W8970 tp-link is configured similarly NethServer - it does not have only OpenVPN and only supports one WAN link
The default route looks like this:
For WAN1: default via 78.11.48.25 dev enp2s0
For WAN2: default via 192.168.1.1 dev enp4s2
Did you setup your multi wan correctly?
http://docs.nethserver.org/en/v7/firewall.html#multi-wan
I changed the settings to active backup as in the example. Is traffic shapping necessary?
No, it’s not needed for multi wan.
