Login to Webtop takes over 6 seconds
as per title, login into Webtop with Nethserver theme take after entering login password over 5/6 seconds before (spinner is showing) the inbox is shown. This a pretty long period. Any idea how to shorten this to immedately show inbox pls?
TIA
All the details are missing.
Hardware specs (and VM specs if it is VM), if it was fast and the became slow etc.
Did you check the logs for anything weird?
This is the admin logging in Webtop admin login - Pastebin.com
And there is also the blow at login:
2024-10-17T21:24:35+02:00 [1:webtop1:webapp] jakarta.mail.AuthenticationFailedException: [UNAVAILABLE] Internal error occurred. Refer to server log for more information.
I don’t know what log to check as per advise above.
The above ‘internal error’ happens after every ‘F5’ or refresh of the whole browser window.
HTH
Can somebody verify if their login into lates webtop also takes a long time pls?
