As an administrator, I can no longer log into my Moodle instance. The password is not accepted. I haven’t changed it since the initial installation. It can no longer be changed in the app settings. Where should I start to solve the problem?
I’m sorry, the Moodle app is broken, it relied on bitnami containers which aren’t available anymore and there’s no official equivalent that’s ready for production.
It’s not possible to install it anymore so I can’t reproduce the issue.
I removed it from my repo now to avoid failing installations.
I’m going to search for a solution like installing it in ns8-lamp or ns8-webserver.
Do you have important data in your Moodle installation? It should be possible to export the database from inside the container.
No, no important data is stored there. I only had the app on the server for testing purposes anyway. I will uninstall it and wait for a new product from your software company.
These are the images for the Moodle app, which is a mobile application to manage a Moodle LMS site.
I’m going to retest the other available images but they’re intended for development AFAICS, see moodlehq/moodle-php-apache - Docker Image
