Login flow + 2FA OTP
I am creating an API to do the OTP verification for a user with 2FA since there is no api for use in curl. I have the code but without the flow between the login and the OTP I cannot continue.
I have the user with 2FA activated, I log in using api rest client
I get a token and I use it to consult
{“path”: “ns.ovpnrw”, “method”: “list-users”, “payload”: {“instance”: “ns_roadwarrior1”}}
But it returns me, I know it’s because of the lack of validation of the otp
“code”: 403,
“data”: null,
“message”: “you don’t have permission to access this resource”
I think there must be a record that validates and generates a different token or when validating otp it is given permissions to use the APIs, (I inquire)
In each token it tells me if 2FA is activated or not but I don’t know if I’m missing something
  "2fa": true,
  "actions": [],
  "exp": 1763601616,
  "id": "User2FA",
  "orig_iat": 1763515216,
  "role": ""
I was going to sleep but I turned my head until I knew how the process is, I found the flow, via web when logging in it does not generate the token but after validating the otp. Tomorrow I will continue until I achieve the use in the app. I will not create the api since I will use the nethsecurity one.
Ready. Tomorrow I will start the development to log in with a 2FA user from the app.
Good morning, developing the update for the use of OTP 2FA in the app, right now it’s in the oven.
