Login failed in web interface Ejabber (remote AD integration)
NethServer 7.7.1908
Ejabberd 1.5.0
Hello, dear friends!!!
Does not pass authorization in the web interface.
At the same time, there are no problems with the work of AD is not observed. Authorization in SOGo, awstat, display of AD names occurs normally.
The user under which I try to go to Ejabberd I added to the jabberadmins group in AD.
Hi Anton,
did you enter a dedicated user in the account provider settings?
http://docs.nethserver.org/en/v7/accounts.html#join-an-existing-active-directory-domain
I tried remote AD to another Nethserver.
The login to the ejabber web interface worked with user@domain.local instead of user@ad.domain.local
