If you are locked out of the web user interface and you can still access a system command-line >shell as root (e.g. by the system recovery console or SSH), run the following command to >disable 2FA and reset the password:
api-cli run alter-user --data '{"user":"admin","set":{"password":"Nethesis,1234","2fa":false}}'
Another option is to wait a bit before login as, depending on system speed and resources, there could be some incomplete task still running in the backgroud. Same suggestion was made in another topic.
I didnât experienced this login problem with cluster-admin but for nextcloud+AD users.
Installed on a tower server.
Created a user during the install.
I am able to use that user name and password to access the server via SSH or directly on the device
When I go to the website I get an error or invalid username and password for the same username and password used to access via SSH
The user you created has no cluster-admin right other than he should be able to access to only change his password. I do not remember the URL to change the password of the created user.
The user root can not login in ssh until you login with the created user, then "su - " using the created userâs pasword; when you are root, give yourself the right to login by âPermitRoorLogin=Yesâ.
Login to cluster -admin as root and make the created user an admin of the cluster.
