NethServer Version: 7.4.1708
Module: ptp4l
Hello,
I’m looking to implement linuxptp on my server in gateway mode to synchronise it with a ptp grandmaster present on my lan (so i’m using ptp4l on green interface).
here you can see some of my config files:
/usr/lib/systemd/system/ptp4l.service:
[Unit]
Description=Precision Time Protocol (PTP) service
[Service]
Type=simple
ExecStart=/usr/sbin/ptp4l -i eno1 -m -f /etc/ptp4l.conf
ExecStop=/bin/pkill -f ptp4l
[Install]
WantedBy=multi-user.target
/etc/ptp4l.conf:
[global]
# Default Data Set
twoStepFlag 1
slaveOnly 0
priority1 128
priority2 128
domainNumber 0
clockClass 248
clockAccuracy 0xFE
offsetScaledLogVariance 0xFFFF
free_running 0
freq_est_interval 1
dscp_event 56
dscp_general 0
# Port Data Set
logAnnounceInterval 1
logSyncInterval -1
logMinDelayReqInterval 0
logMinPdelayReqInterval 0
announceReceiptTimeout 3
syncReceiptTimeout 0
delayAsymmetry 0
fault_reset_interval 2
neighborPropDelayThresh 20000000
# Run time options
assume_two_step 0
logging_level 6
path_trace_enabled 0
follow_up_info 0
hybrid_e2e 0
tx_timestamp_timeout 5
use_syslog 1
verbose 0
summary_interval 6
kernel_leap 1
check_fup_sync 0
# Servo Options
pi_proportional_const 0.17
pi_integral_const 0.0076
pi_proportional_scale 0.0
pi_proportional_exponent -0.3
pi_proportional_norm_max 0.7
pi_integral_scale 0.0
pi_integral_exponent 0.4
pi_integral_norm_max 0.3
step_threshold 0.02
first_step_threshold 0.00002
max_frequency 0
clock_servo pi
sanity_freq_limit 500000000
ntpshm_segment 0
# Transport options
transportSpecific 0x0
ptp_dst_mac 01:1B:19:00:00:00
p2p_dst_mac 01:80:C2:00:00:0E
udp_ttl 5
udp6_scope 0x0E
uds_address /var/run/ptp4l
# Default interface options
network_transport UDPv4
delay_mechanism E2E
time_stamping hardware
tsproc_mode filter
delay_filter moving_median
delay_filter_length 10
egressLatency 0
ingressLatency 0
boundary_clock_jbod 0
# Clock description
productDescription SERVER;NETHSERVER;
revisionData ;;
manufacturerIdentity 00:00:00
userDescription ;
timeSource 0xA0
[eno1]
ifconfig (partial response):
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.254 netmask 255.255.255.0 broadcast 192.168.100.255
ether 90:1b:0e:cf:46:43 txqueuelen 1000 (Ethernet)
RX packets 1051880 bytes 184553354 (176.0 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 653916 bytes 728246906 (694.5 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0xdfa00000-dfa7ffff
ip maddr:
1: lo
inet 224.0.0.1
inet6 ff02::1
inet6 ff01::1
2: eno1
link 01:00:5e:00:00:01
link 01:00:5e:00:00:fb
inet 224.0.0.251
inet 224.0.0.1
inet6 ff02::1
inet6 ff01::1
3: eno2
link 33:33:00:00:00:01
link 33:33:ff:23:c9:28
inet 224.0.0.251
inet 224.0.0.1
inet6 ff02::1:ff23:c928
inet6 ff02::1
inet6 ff01::1
ptp4l(1.8 version) seems to work perfectly but it can’t receive ptp event incoming packets so it always assumes grandmaster role even in slave mode.
On the other side, I’m sure that it can send ptp event packet
I’ve finally suspected a problem with shorewall but when shorewall is stopped,problem persist.
I don’t understand where igmp ptp incoming packets are dropped…
