jgjimenezs
(Jose G Jimenez S )
1
Friends need to put more lines to translate into Transifex
You may add to translate? @davidep
giacomo
(Giacomo Sanchietti)
2
Hi, I will try to respond point by point.
vpn_disabled, the right label is ovpn_disabled : fixed in NS 7
- label days in mail: I think it’s hard (@davidep)
- Applications tab: the labels are not translated at
- Yum error comes directly from the system and it depends on system locale
- Davide already did some tests on DataTable language plugin but it’s quite difficult
jgjimenezs
(Jose G Jimenez S )
3
Ok, do not worry we will keep it that way. and if you change perfect.
