TLDR: Could it be possible to include the libffi-devel packaqe linked to the libffi rpm which is taken from the SOGo repository by nethserver?
http://sogo.nu/files/downloads/SOGo/RHEL6/x86_64/RPMS/libffi-devel-3.0.10-1.x86_64.rpm
Baground
I am having issues installing the letsencrypt client on my nethserver installation.
There is a version missmatch between the libffi package installed (from the nethserver-base repo) and the libffi-devel one available (from the centos-base repo) preventing the installation script to work.
The error message indicates a missmatch between the two packages :
Error: Multilib version problems found. This often means that the root
cause is something else and multilib version checking is just
pointing out that there is a problem. Eg.:
1. You have an upgrade for libffi which is missing some
dependency that another package requires. Yum is trying to
solve this by installing an older version of libffi of the
different architecture. If you exclude the bad architecture
yum will tell you what the root cause is (which package
requires what). You can try redoing the upgrade with
--exclude libffi.otherarch ... this should give you an error
message showing the root cause of the problem.
2. You have multiple architectures of libffi installed, but
yum can only see an upgrade for one of those arcitectures.
If you don't want/need both architectures anymore then you
can remove the one with the missing update and everything
will work.
3. You have duplicate versions of libffi installed already.
You can use "yum check" to get yum show these errors.
...you can also use --setopt=protected_multilib=false to remove
this checking, however this is almost never the correct thing to
do as something else is very likely to go wrong (often causing
much more problems).
Protected multilib versions: libffi-3.0.5-3.2.el6.i686 != libffi-3.0.10-1.x86_64
Could not install additional dependencies. Aborting bootstrap!
Here is the available version from default repositories:
[root@thermos ~/]# yum info libffi-devel
Available Packages
Version : 3.0.5
Repo : centos-base
Installed Packages
Version : 3.0.10
From repo : nethserver-base
The workaround I used is to manually add the SOGo repository to /etc/yum.repos.d/, disable it to avoid any problem. Then install the requisite package with the arg --enablerepo=sogo
Installed Packages
Version : 3.0.10
Repo : sogo
Available Packages
Version : 3.0.5
Repo : centos-base
If you could directly add it to the nethserver one, it would be much simpler to us
Cheers
