The letsencrypt not work. It gives the following message.
More than once I installed again, but not changed. I could not find an answer.
the /var/log/messages and the /var/log/httpd-admin/error might contain more clues, take a look after them please
I sent e-mail. I could not upload here.
could you please try to reproduce the error and just post the snippet of the event, I received some days of logs
yep got it I found it in your /var/log/message
Normally if you look in /etc/sudoers.d/20_nethserver_base the user gets the right to launch a command without password
what about if you launch manually the script /usr/libexec/nethserver/letsencrypt-certs
You can not find the file.
I looked and really was not.
The letsencrypt was not properly installed.
I do not understand why.
After the “yum install nethserver-letsencrypt” everything was good.
Thank you for your guidance.
which one…just for my Information ?
Yes, the information was correct. It helped.
Since I could not find the file. Therefore I installed.
I thought it was all good with me.
Thanks again.
