NethServer Version: 7.6.1810 (final)
Module: Certificates
Hi - Nethserver seems to be using an old certificate with apache. If I go to the Server Certificates section in the web admin panel, it says
/etc/letsencrypt/live/rnet.duckdns.org-0001/cert.pem Let's Encrypt Authority X3 2019-06-27 /etc/letsencrypt/live/rnet.duckdns.org-0001/cert.pem Let's Encrypt Authority X3 2019-06-27 (tick)
If I go to the Virtual Hosts section, edit a virtual host and tell it to use this certificate, I can vist the site no problems.
If the virtual host is configured to use the default certificate, I get an invalid certificate error, and told the certificate has expired. The certificate being served expired this morning.
I’ve rebooted, restarted apache and so on.
