@happnatious1 Yes, I remember that now. But, I did not open port 80, seems like a security hole to me as well.
My plan, which I forgot, was to open up port 80 to do the update (certbot renew), and then close it again.
So, I did this, and I get the following error;
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /etc/letsencrypt/renewal/office.mydomain.com.conf
Cert is due for renewal, auto-renewing…
Starting new HTTPS connection (1): acme-v01.api.letsencrypt.org
Renewing an existing certificate
Performing the following challenges:
http-01 challenge for office.mydomain.com
Waiting for verification…
Cleaning up challenges
Attempting to renew cert from /etc/letsencrypt/renewal/office.mydomain.com.conf produced an unexpected error: Failed authorization procedure. office.lo
ndonrooftruss.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://office.mydomain.c
om/.well-known/acme-challenge/w3rH1Q5-xCfgrOSPYfVq_aMdYULzlFgontpNz5Ybfg8: "
<meta http-equiv=“X-UA-Compatible” content=“IE=edge”. Skipping.
All renewal attempts failed. The following certs could not be renewed:
/etc/letsencrypt/live/office.mydomain.com/fullchain.pem (failure)
1 renew failure(s), 0 parse failure(s)
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: office.mydomain.com
Type: unauthorized
Detail: Invalid response from
http://office.mydomain.com/.well-known/acme-challenge/w3rH1Q5-xCfgrOSPYfVq_aMdYULzlFgontpNz5Ybfg8:
<"!DOCTYPE HTML PUBLIC “-//IETF//DTD HTML 2.0//EN”>
HTML>HEAD>
TITLE>404 Not Found
/HEAD>BODY>
H1>Not Found
Th"
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A record(s) for that domain
contain(s) the right IP address
