Let's Encrypt not working
Operating system: NethSecurity 8 23.05.3-ns.0.0.3-rc1
All Let’s Encrypt certs are pending.
Logs show " Apr 12 11:13:50 NethSec acme: Option “standalone” is deprecated."
I know that acme has been updated on the latest OpenWrt because of a bug.
But I did not test it.
Before trying to reproduce, are you sure that your machine meets all the requirements?
https://docs.nethsecurity.org/en/latest/reverse_proxy.html#let-s-encrypt
Yes, ports 443 and 80 are open from the internet to NethSecurity. I tested this on the previous version and it worked successfully in in that version.
It seems I can reproduce, try to execute from command line:
/etc/init.d/acme restart
It should give this error:
acme: Option "standalone" is deprecated.
acme: Please set "option validation_method standalone".
/usr/lib/acme/hook: line 47: keylength: parameter not set
There is an upstream issue, but the fix seems not related.
I will search for a fix next week.
Thanks for reporting!
I’ve opened an issue: Let’s Encrypt not working · Issue #417 · NethServer/nethsecurity · GitHub
It’s already fixed inside the image Let’s Encrypt not working · Issue #417 · NethServer/nethsecurity · GitHub
