LemonLDAP-NG in Podman
add-module ghcr.io/stephdl/lemonldapng:firstrelease
now I have to autoconfigure the backend to ldap
add-module ghcr.io/stephdl/lemonldapng:1.0.0-dev.1
you have to make some dns entries to the fqdn you choose
auth.domain.com
manager.domain.com
reload.domain.com (not sure)
test1.domain.com
test2.domain.com
user pwd
rtyler rtyler (user)
dwho dwho (administrator)
go to auth.domain.com and test the demo app
go to the manager and play
what should work
configuration
restore/backup
clone
smarthost smtp if set in the server
ldap setting in the ui (todo autoconfiguration of the LDAP)
@dan what do you think ?
I do miss Rose, though they’ve had a number of good companions since her. I’ll have to take a look at the module.
Sorry for lack of reply the last 2 weeks we were dealing with a tropical cyclone it didn’t end up being as bad as they thought but it covered such a large area (we prepared and were fine but it mostly took out supply lines for a few days and power and internet)
I’ll have a look at the module as soon as I can thanks so much for your help
using the add-module ghcr.io/stephdl/lemonldapng:1.0.0-dev.1 installs it but after configuration I just get bad gateway and using
add-module ghcr.io/nethserver/lemonldapng:latest 1
Results in
Error
<7>podman-pull-missing ghcr.io/nethserver/lemonldapng:latest
Trying to pull ghcr.io/nethserver/lemonldapng:latest...
Error: initializing source docker://ghcr.io/nethserver/lemonldapng:latest: Requesting bearer token: invalid status code from registry 403 (Forbidden)
  File "/usr/local/agent/bin/podman-pull-missing", line 35, in <module>
    subprocess.run(['podman', 'pull', image_url]).check_returncode()
  File "/usr/lib64/python3.11/subprocess.py", line 502, in check_returncode
subprocess.CalledProcessError: Command '['podman', 'pull', 'ghcr.io/nethserver/lemonldapng:latest']' returned non-zero exit status 125.
  File "/var/lib/nethserver/cluster/actions/add-module/50update", line 64, in <module>
    agent.run_helper('podman-pull-missing', image_url, progress_callback=agent.get_progress_callback(0,33)).check_returncode()
subprocess.CalledProcessError: Command '('podman-pull-missing', 'ghcr.io/nethserver/lemonldapng:latest')' returned non-zero exit status 1.
which I’m assuming is because it’s not in Nethserver repo yet and the above cmd is a placeholder
*Update
ok I reinstalled it using add-module ghcr.io/stephdl/lemonldapng:latest 1
Summary
<7>podman-pull-missing ghcr.io/stephdl/lemonldapng:latest
Trying to pull ghcr.io/stephdl/lemonldapng:latest...
Copying blob sha256:37e83647a72b3ef2696e56e2e8323ec4142276b757df5157d573f54898c34200
Copying config sha256:a17f0833ac94fa67e4d2fc900c88b857fb7b5bacb6b03405cd615b9cc9e1bec7
<7>extract-ui ghcr.io/stephdl/lemonldapng:latest
Extracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/lemonldapng5
ui/css/
ui/css/about~31ecd969.f3b8eb2f.css
ui/css/app~748942c6.b5333564.css
ui/i18n/
ui/i18n/de/
ui/i18n/de/translation.json
ui/i18n/en/
ui/i18n/en/translation.json
ui/i18n/es/
ui/i18n/es/translation.json
ui/i18n/eu/
ui/i18n/eu/translation.json
ui/i18n/it/
ui/i18n/it/translation.json
ui/i18n/pt/
ui/i18n/pt/translation.json
ui/i18n/pt_BR/
ui/i18n/pt_BR/translation.json
ui/img/
ui/img/module_default_logo.b3bbdb98.png
ui/index.html
ui/js/
ui/js/about~31ecd969.4bed3e85.js
ui/js/about~31ecd969.4bed3e85.js.map
ui/js/app~748942c6.341e9975.js
ui/js/app~748942c6.341e9975.js.map
ui/js/chunk-vendors~0605657e.7f254d6a.js
ui/js/chunk-vendors~0605657e.7f254d6a.js.map
ui/js/chunk-vendors~0f485567.68e9337c.js
ui/js/chunk-vendors~0f485567.68e9337c.js.map
ui/js/chunk-vendors~17faf02d.7f68aab6.js
ui/js/chunk-vendors~17faf02d.7f68aab6.js.map
ui/js/chunk-vendors~1d97ff09.290bda9d.js
ui/js/chunk-vendors~1d97ff09.290bda9d.js.map
ui/js/chunk-vendors~2a42e354.0df57e14.js
ui/js/chunk-vendors~2a42e354.0df57e14.js.map
ui/js/chunk-vendors~2aa62147.38204dba.js
ui/js/chunk-vendors~2aa62147.38204dba.js.map
ui/js/chunk-vendors~41d44f25.e7779fa1.js
ui/js/chunk-vendors~41d44f25.e7779fa1.js.map
ui/js/chunk-vendors~46852254.0b6d19c2.js
ui/js/chunk-vendors~46852254.0b6d19c2.js.map
ui/js/chunk-vendors~57473a66.f586d2ed.js
ui/js/chunk-vendors~57473a66.f586d2ed.js.map
ui/js/chunk-vendors~5bb1f863.3efba861.js
ui/js/chunk-vendors~5bb1f863.3efba861.js.map
ui/js/chunk-vendors~5eba3806.b8428291.js
ui/js/chunk-vendors~5eba3806.b8428291.js.map
ui/js/chunk-vendors~690b702c.fd888ae3.js
ui/js/chunk-vendors~690b702c.fd888ae3.js.map
ui/js/chunk-vendors~7274e1de.72bc2eab.js
ui/js/chunk-vendors~7274e1de.72bc2eab.js.map
ui/js/chunk-vendors~86f6b1bc.6688193d.js
ui/js/chunk-vendors~86f6b1bc.6688193d.js.map
ui/js/chunk-vendors~b5906859.deff14e4.js
ui/js/chunk-vendors~b5906859.deff14e4.js.map
ui/js/chunk-vendors~bc21d4b3.68b10b46.js
ui/js/chunk-vendors~bc21d4b3.68b10b46.js.map
ui/js/chunk-vendors~be71a85b.9c367aa3.js
ui/js/chunk-vendors~be71a85b.9c367aa3.js.map
ui/js/chunk-vendors~c8728516.dd1ccc58.js
ui/js/chunk-vendors~c8728516.dd1ccc58.js.map
ui/js/chunk-vendors~d2305125.6a99a4ff.js
ui/js/chunk-vendors~d2305125.6a99a4ff.js.map
ui/js/chunk-vendors~d9886323.1a1a66f6.js
ui/js/chunk-vendors~d9886323.1a1a66f6.js.map
ui/js/chunk-vendors~db300d2f.ddb8641c.js
ui/js/chunk-vendors~db300d2f.ddb8641c.js.map
ui/js/chunk-vendors~ec8c427e.5c1734c3.js
ui/js/chunk-vendors~ec8c427e.5c1734c3.js.map
ui/js/chunk-vendors~fdc6512a.81c5c86c.js
ui/js/chunk-vendors~fdc6512a.81c5c86c.js.map
ui/js/lang-de-translation-json~3c620948.e0b5ebcd.js
ui/js/lang-de-translation-json~3c620948.e0b5ebcd.js.map
ui/js/lang-en-translation-json~9b60384d.f9865989.js
ui/js/lang-en-translation-json~9b60384d.f9865989.js.map
ui/js/lang-es-translation-json~f7c30340.434383b0.js
ui/js/lang-es-translation-json~f7c30340.434383b0.js.map
ui/js/lang-eu-translation-json~8ed4c5c2.33ab4b3c.js
ui/js/lang-eu-translation-json~8ed4c5c2.33ab4b3c.js.map
ui/js/lang-it-translation-json~e043826f.e33749b0.js
ui/js/lang-it-translation-json~e043826f.e33749b0.js.map
ui/js/lang-pt-translation-json~45d767f3.8b3eaa68.js
ui/js/lang-pt-translation-json~45d767f3.8b3eaa68.js.map
ui/js/lang-pt_BR-translation-json~eef7148a.487e22b9.js
ui/js/lang-pt_BR-translation-json~eef7148a.487e22b9.js.map
ui/metadata.json
ui/shortcuts.json
a2c1a65f195f855d65f329dbfd2fe59c4759eaca743ef99e5b809d44f92399f2
{'module_id': 'lemonldapng5', 'image_name': 'lemonldapng', 'image_url': 'ghcr.io/stephdl/lemonldapng:latest'}
and here is the log
Log
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Queued start job for default target Main User Target.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Created slice User Application Slice.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Started Mark boot as successful after the user session has run 2 minutes.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Started Daily Cleanup of User's Temporary Directories.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Reached target Paths.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Reached target Timers.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Starting D-Bus User Message Bus Socket...
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Starting Create User's Volatile Files and Directories...
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Listening on D-Bus User Message Bus Socket.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Reached target Sockets.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Finished Create User's Volatile Files and Directories.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Reached target Basic System.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Started Rootless module/lemonldapng5 agent.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Reached target Main User Target.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:systemd] Startup finished in 336ms.
2025-03-17T10:08:39+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/4e1d80b3-2bb5-4139-a8dd-d9277e43c4cf: create-module/05pullimages is starting
2025-03-17T10:08:40+10:00 [1:lemonldapng5:agent@lemonldapng5] Add to module/lemonldapng5 environment LEMONLDAP_NG_IMAGE=docker.io/lemonldapng/lemonldap-ng:2.20.2
2025-03-17T10:08:40+10:00 [1:lemonldapng5:agent@lemonldapng5] podman-pull-missing docker.io/lemonldapng/lemonldap-ng:2.20.2
2025-03-17T10:08:42+10:00 [1:lemonldapng5:systemd] Starting D-Bus User Message Bus...
2025-03-17T10:08:42+10:00 [1:lemonldapng5:dbus-broker-launch] Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
2025-03-17T10:08:42+10:00 [1:lemonldapng5:dbus-broker-launch] Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
2025-03-17T10:08:42+10:00 [1:lemonldapng5:systemd] Started D-Bus User Message Bus.
2025-03-17T10:08:42+10:00 [1:lemonldapng5:] Ready
2025-03-17T10:08:42+10:00 [1:lemonldapng5:systemd] Created slice Slice /user.
2025-03-17T10:08:42+10:00 [1:lemonldapng5:systemd] podman-pause-f0cd5adb.scope: unit configures an IP firewall, but not running as root.
2025-03-17T10:08:42+10:00 [1:lemonldapng5:systemd] (This warning is only shown for the first unit using IP firewalling.)
2025-03-17T10:08:42+10:00 [1:lemonldapng5:systemd] Started podman-pause-f0cd5adb.scope.
2025-03-17T10:08:42+10:00 [1:lemonldapng5:agent@lemonldapng5] Trying to pull docker.io/lemonldapng/lemonldap-ng:2.20.2...
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Getting image source signatures
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:02508d19d486a7cbdc3f59e4cc023682a8889e8c154e68ad99ec06b8be1e4417
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:4ac7be88906ac271433a18feaf7017b091687b2d0fd9eb99e4fe96fd5d5fc7f6
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:fb2f953d61a74ddb42bd7b8929db539e4a8b9ad4b3f97d87bc3987971899c9c6
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:35442ebc756098b2dfffc9ca9e20b654e6b595ad5cf251752db4db7853f87934
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:84ac79118ba1b870c8b2f4da2b40e8a8371f15d1fe928be496dfa5127051d636
2025-03-17T10:08:46+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:0d5304ce9fda24b168d8bf57508061704631da7ed0a6831fb007ff6e39d4d94c
2025-03-17T10:08:47+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:f8816cca4cae1aea578c8d8e941a990a4cfb6e785efd7b27f5f4f6293cf83e55
2025-03-17T10:08:48+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:67cbac1479e0ca0b63d4f50b58ee283fbf8c9110bd323e5dcfa03ae530c23f26
2025-03-17T10:08:48+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:1674377cf61390bd304219ce38701aa3ba6373dd47427049315a6334efc75534
2025-03-17T10:08:48+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying blob sha256:9ad2cd93ad05c64dcd743e23f2b972dab635816539472a809457a44ef73ab8ca
2025-03-17T10:10:04+10:00 [1:lemonldapng5:agent@lemonldapng5] Copying config sha256:0ea8d0388a80de66c20a28646a902ab13b87e1f3f00b8eca82c471985b836c10
2025-03-17T10:10:04+10:00 [1:lemonldapng5:agent@lemonldapng5] Writing manifest to image destination
2025-03-17T10:10:04+10:00 [1:lemonldapng5:agent@lemonldapng5] 0ea8d0388a80de66c20a28646a902ab13b87e1f3f00b8eca82c471985b836c10
2025-03-17T10:10:04+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/4e1d80b3-2bb5-4139-a8dd-d9277e43c4cf: create-module/10selfadm_role is starting
2025-03-17T10:10:05+10:00 [1:lemonldapng5:agent@lemonldapng5] 1
2025-03-17T10:10:05+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/4e1d80b3-2bb5-4139-a8dd-d9277e43c4cf: action "create-module" status is "completed" (0) at step 10selfadm_role
2025-03-17T10:10:47+10:00 [1:lemonldapng5:systemd] Starting Mark boot as successful...
2025-03-17T10:10:47+10:00 [1:lemonldapng5:systemd] Finished Mark boot as successful.
2025-03-17T10:11:01+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ad2da56a-ba39-4eea-9bca-ccae1033cad9: get-name/50get_name is starting
2025-03-17T10:11:02+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/14b00a97-2fcf-40a8-9a9d-9db614131dc1: get-configuration/20read is starting
2025-03-17T10:11:02+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/eef70af9-c063-4c0e-ac55-f5ba229f523b: get-status/20read is starting
2025-03-17T10:11:02+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ad2da56a-ba39-4eea-9bca-ccae1033cad9: action "get-name" status is "completed" (0) at step 50get_name
2025-03-17T10:11:02+10:00 [1:lemonldapng5:agent@lemonldapng5] agent.ldapproxy: domain ad.ksatdesign.com.au should not be used by lemonldapng5. Invoke agent.bind_user_domains(["ad.ksatdesign.com.au"]) to fix this warning.
2025-03-17T10:11:02+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/14b00a97-2fcf-40a8-9a9d-9db614131dc1: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:03+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/eef70af9-c063-4c0e-ac55-f5ba229f523b: action "get-status" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:07+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/bfe4b1ab-545e-4600-9a58-252f7f758a79: get-configuration/20read is starting
2025-03-17T10:11:08+10:00 [1:lemonldapng5:agent@lemonldapng5] agent.ldapproxy: domain ad.ksatdesign.com.au should not be used by lemonldapng5. Invoke agent.bind_user_domains(["ad.ksatdesign.com.au"]) to fix this warning.
2025-03-17T10:11:08+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/bfe4b1ab-545e-4600-9a58-252f7f758a79: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:38+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ac3436cb-2377-4f73-89a5-3d65dc82417d: configure-module/01Hostname_validation is starting
2025-03-17T10:11:39+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ac3436cb-2377-4f73-89a5-3d65dc82417d: configure-module/10configure_environment_vars is starting
2025-03-17T10:11:40+10:00 [1:lemonldapng5:agent@lemonldapng5] _acontrol_task request attempt failed (WS reached EOF while waiting for cluster/task/ef415974-10e6-4af8-8dee-2090308bd255). Retrying...
2025-03-17T10:11:45+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ac3436cb-2377-4f73-89a5-3d65dc82417d: configure-module/20configure_traefik is starting
2025-03-17T10:11:45+10:00 [1:lemonldapng5:agent@lemonldapng5] dump_env() is deprecated and implemented as a no-op
2025-03-17T10:11:46+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/1b0d574e-8500-4636-b2c0-3000a0abc67b: get-configuration/20read is starting
2025-03-17T10:11:46+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/58948a59-2249-402b-9f77-31d5e1307efd: get-status/20read is starting
2025-03-17T10:11:47+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/1b0d574e-8500-4636-b2c0-3000a0abc67b: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:47+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/58948a59-2249-402b-9f77-31d5e1307efd: action "get-status" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:57+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/b04e7a4f-8288-4503-a09f-1defc52d0e8a: get-configuration/20read is starting
2025-03-17T10:11:57+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/3472577d-7795-4d96-a257-2f221481f5b3: get-configuration/20read is starting
2025-03-17T10:11:58+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/54444191-bc66-4d3e-9f0f-bd2fd19824c0: get-status/20read is starting
2025-03-17T10:11:58+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/b04e7a4f-8288-4503-a09f-1defc52d0e8a: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:58+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/3472577d-7795-4d96-a257-2f221481f5b3: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:11:58+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/54444191-bc66-4d3e-9f0f-bd2fd19824c0: action "get-status" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:02+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ac3436cb-2377-4f73-89a5-3d65dc82417d: configure-module/80start_services is starting
2025-03-17T10:12:02+10:00 [1:lemonldapng5:agent@lemonldapng5] Created symlink /home/lemonldapng5/.config/systemd/user/default.target.wants/lemonldapng.service → /home/lemonldapng5/.config/systemd/user/lemonldapng.service.
2025-03-17T10:12:02+10:00 [1:lemonldapng5:systemd] Reloading.
2025-03-17T10:12:03+10:00 [1:lemonldapng5:systemd] Starting Podman lemonldapng.service...
2025-03-17T10:12:04+10:00 [1:lemonldapng5:systemd] Created slice cgroup user-libpod_pod_f6415a420be4b729c73994965c421d278b0d933af311638aee6fac3ed8cbfdf1.slice.
2025-03-17T10:12:05+10:00 [1:lemonldapng5:podman] f6415a420be4b729c73994965c421d278b0d933af311638aee6fac3ed8cbfdf1
2025-03-17T10:12:05+10:00 [1:lemonldapng5:systemd] Started libcrun container.
2025-03-17T10:12:05+10:00 [1:lemonldapng5:systemd] Started Podman lemonldapng.service.
2025-03-17T10:12:05+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ac3436cb-2377-4f73-89a5-3d65dc82417d: action "configure-module" status is "completed" (0) at step 80start_services
2025-03-17T10:12:05+10:00 [1:lemonldapng5:systemd] Starting Podman  lemonldapng-app.service...
2025-03-17T10:12:06+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/a1199764-4d69-4747-bae6-3d531a9bbdc3: get-configuration/20read is starting
2025-03-17T10:12:07+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/a1199764-4d69-4747-bae6-3d531a9bbdc3: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:09+10:00 [1:lemonldapng5:systemd] Started libcrun container.
2025-03-17T10:12:09+10:00 [1:lemonldapng5:lemonldapng-app] Starting periodic command scheduler: cron.
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Starting anac(h)ronistic cron: anacron.
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] # Changing nginx port to 80
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng5] d064565d4b5d142008304107db0f7f5bf8675c09e548a586da52ebf3bce01885
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Remove the SOCKET variable
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Add LISTEN variable
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Update NGinx configuration from UNIX socket to TCP socket
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] sed: can't read /etc/nginx/sites-enabled/*-nginx.conf: No such file or directory
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Update upstream llng fastcgi to tcpsocket
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] sed: can't read /etc/nginx/sites-enabled/portal-nginx.conf: No such file or directory
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Exporting environment variables
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Starting fast-cgi-server
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Starting llng-fastcgi-server: llng-fastcgi-serverFastCGI daemon started (pid 50)
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] .
2025-03-17T10:12:10+10:00 [1:lemonldapng5:lemonldapng-app] Starting nginx
2025-03-17T10:12:11+10:00 [1:lemonldapng5:lemonldapng5] podman exec lemonldapng-app /usr/share/lemonldap-ng/bin/lemonldap-ng-cli -yes 1 set SMTPAuthPass '' SMTPAuthUser '' SMTPServer 10.6.4.1 SMTPTLS '' SMTPPort 25
2025-03-17T10:12:11+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/d2f0ca37-6896-48de-a04d-23a2af8c66cb: get-configuration/20read is starting
2025-03-17T10:12:12+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/d2f0ca37-6896-48de-a04d-23a2af8c66cb: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:12+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/01466109-7dc4-40f4-a1f5-847cc0f30936: get-configuration/20read is starting
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5] Saved under number 2
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5] [Mon Mar 17 00:12:12 2025] [LLNG:65] [error] Apply configuration for localhost: error 500 (Can't connect to localhost:80 (Connection refused))
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5]             'localhost' => 'Error 500 (Can\'t connect to localhost:80 (Connection refused))'
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5]           {
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5]           }
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5]         ];
2025-03-17T10:12:12+10:00 [1:lemonldapng5:lemonldapng5] Status  : [
2025-03-17T10:12:12+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/347637a3-26d3-4a3e-8f67-bbcfe194269b: get-status/20read is starting
2025-03-17T10:12:12+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/01466109-7dc4-40f4-a1f5-847cc0f30936: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:13+10:00 [1:lemonldapng5:systemd] Started Podman  lemonldapng-app.service.
2025-03-17T10:12:13+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/347637a3-26d3-4a3e-8f67-bbcfe194269b: action "get-status" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:37+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/cdb60444-75ca-4207-8eae-3864ff6885b6: get-configuration/20read is starting
2025-03-17T10:12:38+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/cdb60444-75ca-4207-8eae-3864ff6885b6: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:38+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/770b67bb-3576-4de3-a4e4-0a222edc7ffb: get-configuration/20read is starting
2025-03-17T10:12:39+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ed076936-a6ad-468e-93be-849727b59ebf: get-status/20read is starting
2025-03-17T10:12:39+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/770b67bb-3576-4de3-a4e4-0a222edc7ffb: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-03-17T10:12:40+10:00 [1:lemonldapng5:agent@lemonldapng5] task/module/lemonldapng5/ed076936-a6ad-468e-93be-849727b59ebf: action "get-status" status is "completed" (0) at step validate-output.json
and unfortunately still results in Bad Gateway
I try, maybe I have a fast machine and we need to implement a test to verify the container is fully up
i can reproduce, but I still do not understand why
To be fair I’ve done absolutely nothing in regard to debugging yet (it could be my machine or setup)
absolutely not, the concern is inside the container I use, I should check today
add-module ghcr.io/stephdl/lemonldapng:1.0.0-dev.2
The container itself got an issue, I switched to coudot’s container, I need to make a bug report
Openldap workable, lets go to samba AD
this one loads
add-module ghcr.io/stephdl/lemonldapng:1.0.0-dev.4
the LDAP should be workable, AD and LDAP, basically the administrator is the master user, but any user of the ldap could login
user inside domain admins are also administrator
We could create a dedicated group for this
like ssoadmins
thoughts ???
@shane @dan if you want to play to allow apps inside the SSO, I am curious
And we have the mail field
thanks @davidep
this version works well, if I go through and workout the mapping for the additional variable do you think we could add those to the default exported variables (i.e., sn- surname, givenName, etc.) it would make things a lot easier in terms of setting up saml.
at the moment the variables I have are
I’m sure there is more to add (i.e., address, website, etc) but this gives a good amount of integration options for apps
Update: I’ve tried locating the image files (i.e., logos, apps and backgrounds) but I can’t find them maybe they need to be created as separate volumes that link to the Podman image
No problem
continue to study your needs we can implement it
is that what you are looking for, so
runagent -m lemonldapng1
cd llng
I need to write the readme
@Shane_Treweek what do you think
What you showed seemed a bit specific, anyway please argue if not
This is good your right about mine being a bit specific
Ok
let me release a new testing version
after what it could be fun is to write a howto on how to protect some apps like mattermost or nextcloud
