NethServer Version: 7.4
I ran yum update and during this process I lost connection to the server (I stupidly forgot to run this in screen).
When I reran yum update, I receive the following error message:
Error: Multilib version problems found. This often means that the root
cause is something else and multilib version checking is just
pointing out that there is a problem. Eg.:
1. You have an upgrade for libgcc which is missing some
dependency that another package requires. Yum is trying to
solve this by installing an older version of libgcc of the
different architecture. If you exclude the bad architecture
yum will tell you what the root cause is (which package
requires what). You can try redoing the upgrade with
--exclude libgcc.otherarch ... this should give you an error
message showing the root cause of the problem.
2. You have multiple architectures of libgcc installed, but
yum can only see an upgrade for one of those architectures.
If you don't want/need both architectures anymore then you
can remove the one with the missing update and everything
will work.
3. You have duplicate versions of libgcc installed already.
You can use "yum check" to get yum show these errors.
...you can also use --setopt=protected_multilib=false to remove
this checking, however this is almost never the correct thing to
do as something else is very likely to go wrong (often causing
much more problems).
Protected multilib versions: libgcc-4.8.5-16.el7_4.2.i686 != libgcc-4.8.5-16.el7_4.1.x86_64
Error: Protected multilib versions: systemd-libs-219-42.el7_4.10.i686 != systemd-libs-219-42.el7_4.7.x86_64
I can see that the following packages where updated:
Mar 18 16:24:37 Updated: php-common-5.4.16-43.el7_4.1.x86_64
Mar 18 16:24:38 Updated: libgcc-4.8.5-16.el7_4.2.x86_64
Mar 18 16:24:39 Updated: systemd-libs-219-42.el7_4.10.x86_64
If I run sudo yum downgrade systemd-libs libgcc php-common, I get the following:
Loaded plugins: auto-update-debuginfo, changelog, fastestmirror, nethserver_events
* base: www.mirrorservice.org
* epel: www.mirrorservice.org
* epel-debuginfo: www.mirrorservice.org
* extras: mirror.mhd.uk.as44574.net
* nethforge: mirror.nordest.systems
* nethserver-base: mirror.nordest.systems
* nethserver-updates: mirror.nordest.systems
* nux-dextop: mirror.li.nux.ro
* updates: mirror.mhd.uk.as44574.net
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction, or "yum-complete-transaction --cleanup-only" and "yum history redo last", first to finish them. If those don't work you'll have to try removing/installing packages by hand (maybe package-cleanup can help).
--> Running transaction check
---> Package libgcc.i686 0:4.8.5-16.el7 will be a downgrade
---> Package libgcc.i686 0:4.8.5-16.el7_4.1 will be erased
---> Package libgcc.x86_64 0:4.8.5-16.el7_4.1 will be a downgrade
---> Package libgcc.x86_64 0:4.8.5-16.el7_4.2 will be erased
---> Package php-common.x86_64 0:5.4.16-43.el7_4 will be a downgrade
---> Package php-common.x86_64 0:5.4.16-43.el7_4.1 will be erased
---> Package systemd-libs.i686 0:219-42.el7_4.6 will be a downgrade
---> Package systemd-libs.i686 0:219-42.el7_4.7 will be erased
---> Package systemd-libs.x86_64 0:219-42.el7_4.7 will be a downgrade
---> Package systemd-libs.x86_64 0:219-42.el7_4.10 will be erased
Error: Package: systemd-219-42.el7_4.10.x86_64 (installed)
Requires: systemd-libs = 219-42.el7_4.10
Removing: systemd-libs-219-42.el7_4.7.i686 (@updates)
systemd-libs = 219-42.el7_4.7
Downgraded By: systemd-libs-219-42.el7_4.6.i686 (updates)
systemd-libs = 219-42.el7_4.6
Removing: systemd-libs-219-42.el7_4.10.x86_64 (installed)
Downgraded By: systemd-libs-219-42.el7_4.7.x86_64 (updates)
Available: systemd-libs-219-42.el7.i686 (base)
Available: systemd-libs-219-42.el7_4.1.i686 (updates)
Available: systemd-libs-219-42.el7_4.4.i686 (updates)
systemd-libs = 219-42.el7_4.4
You could try using --skip-broken to work around the problem
** Found 4 pre-existing rpmdb problem(s), 'yum check' output follows:
libgcc-4.8.5-16.el7_4.2.x86_64 is a duplicate with libgcc-4.8.5-16.el7_4.1.x86_64
php-common-5.4.16-43.el7_4.1.x86_64 is a duplicate with php-common-5.4.16-43.el7_4.x86_64
systemd-219-42.el7_4.10.x86_64 is a duplicate with systemd-219-42.el7_4.7.x86_64
systemd-libs-219-42.el7_4.10.x86_64 is a duplicate with systemd-libs-219-42.el7_4.7.x86_64
If I start running yum-complete-transaction, it runs for quite a bit of time before I stop it as its doing a lots of checks and continually refers to removing a lot packages (including packages for Nethserver to operate) and I am not at all a fan of removing a shed load of packages and then having to reinstall and reconfigure the Nethserver installation.
This one has me really screwed over and I don’t know how to fix it without breaking things…
Any good recommendations on how to fix this?
