I have had two (maybe three) instances over about 4 months where the system stops routing traffic to/from the Internet. Forcing power off from the front panel shutdown button and rebooting works until the next one. As a guess it is either a NIC driver bug, or a bad NIC. This is an older Asus Core 2 Duo motherboard with an on-board NIC (Realtek, I think) and an add-in Broadcom NIC. I can put in another PCI NIC and try some experiments in a few days (on the weekend).
In the log, I see a log of these messages, something like 5 to 15 per second.
Feb 13 14:21:07 roy kernel: r8169 0000:01:00.0 enp1s0: rtl_counters_cond == 1 (loop: 1000, delay: 10).
(note I manually added space in the log at this point just above teh cut here message:
------------[ cut here ]------------
Feb 13 14:21:07 roy kernel: WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:356 dev_watchdog+0x248/0x260
Feb 13 14:21:07 roy kernel: NETDEV WATCHDOG: enp3s0 (tg3): transmit queue 0 timed out
Feb 13 14:21:07 roy kernel: Modules linked in: ifb tcp_diag inet_diag cmac arc4 md4 nls_utf8 cifs ccm dns_resolver xt_recent xt_comment xt_multiport xt_hashlimit xt_addrtype xt_TCPMSS xt_connmark xt_mark xt_CT sch_fq_codel xt_ndpi(OE) xt_NFLOG nf_log_ipv4 nf_log_common xt_LOG nf_conntrack_sane nf_conntrack_netlink nf_nat_tftp nf_nat_snmp_basic nf_conntrack_snmp nf_nat_sip nf_nat_pptp nf_nat_proto_gre nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat_amanda nf_conntrack_tftp nf_conntrack_sip nf_conntrack_pptp nf_conntrack_proto_gre nf_conntrack_netbios_ns nf_conntrack_broadcast nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp ts_kmp nf_conntrack_amanda xt_state iptable_raw xt_CHECKSUM iptable_mangle ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack
Feb 13 14:21:07 roy kernel: ipt_REJECT nf_reject_ipv4 bridge stp llc nfnetlink_queue nfnetlink_log ebtable_filter ebtables tun ip6table_filter ip6_tables devlink iptable_filter binfmt_misc ip_set_hash_ip ip_set nfnetlink sunrpc iTCO_wdt iTCO_vendor_support gpio_ich coretemp kvm_intel kvm irqbypass snd_hda_codec_via snd_hda_codec_generic pcspkr sg snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_seq snd_seq_device tpm_infineon asus_atk0110 snd_pcm snd_timer snd lpc_ich soundcore acpi_cpufreq ip_tables xfs libcrc32c sd_mod crc_t10dif crct10dif_generic crct10dif_common sr_mod cdrom ata_generic pata_acpi i915 serio_raw tg3 ata_piix libata ptp pps_core i2c_algo_bit video iosf_mbi drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm r8169 mii drm_panel_orientation_quirks dm_mirror dm_region_hash dm_log
Feb 13 14:21:07 roy kernel: dm_mod [last unloaded: ifb]
Feb 13 14:21:07 roy kernel: CPU: 0 PID: 0 Comm: swapper/0 Tainted: G OE ------------ 3.10.0-957.5.1.el7.x86_64 #1
Feb 13 14:21:07 roy kernel: Hardware name: System manufacturer System Product Name/P5G41-M LX2/GB, BIOS 0501 05/04/2010 Feb 13 14:21:07 roy kernel: Call Trace:
Feb 13 14:21:07 roy kernel: <IRQ> [<ffffffffb2561e41>] dump_stack+0x19/0x1b
Feb 13 14:21:07 roy kernel: [<ffffffffb1e97688>] __warn+0xd8/0x100
Feb 13 14:21:07 roy kernel: [<ffffffffb1e9770f>] warn_slowpath_fmt+0x5f/0x80
Feb 13 14:21:07 roy kernel: [<ffffffffb2465c38>] dev_watchdog+0x248/0x260
Feb 13 14:21:07 roy kernel: [<ffffffffb24659f0>] ? dev_deactivate_queue.constprop.26+0x60/0x60
Feb 13 14:21:07 roy kernel: [<ffffffffb1ea7f98>] call_timer_fn+0x38/0x110
Feb 13 14:21:07 roy kernel: [<ffffffffb1eaa3fd>] run_timer_softirq+0x24d/0x300
Feb 13 14:21:07 roy kernel: [<ffffffffb1ea0f45>] __do_softirq+0xf5/0x280
Feb 13 14:21:07 roy kernel: [<ffffffffb257832c>] call_softirq+0x1c/0x30
Feb 13 14:21:07 roy kernel: [<ffffffffb1e2e675>] do_softirq+0x65/0xa0
Feb 13 14:21:07 roy kernel: [<ffffffffb1ea12c5>] irq_exit+0x105/0x110
Feb 13 14:21:07 roy kernel: [<ffffffffb25796c8>] smp_apic_timer_interrupt+0x48/0x60
Feb 13 14:21:07 roy kernel: [<ffffffffb2575df2>] apic_timer_interrupt+0x162/0x170
Feb 13 14:21:07 roy kernel: <EOI> [<ffffffffb2569aa0>] ? __cpuidle_text_start+0x8/0x8
Feb 13 14:21:07 roy kernel: [<ffffffffb2569ca6>] ? native_safe_halt+0x6/0x10
Feb 13 14:21:07 roy kernel: [<ffffffffb2569abe>] default_idle+0x1e/0xc0
Feb 13 14:21:07 roy kernel: [<ffffffffb1e366f0>] arch_cpu_idle+0x20/0xc0
Feb 13 14:21:07 roy kernel: [<ffffffffb1efc4da>] cpu_startup_entry+0x14a/0x1e0
Feb 13 14:21:07 roy kernel: [<ffffffffb254ff37>] rest_init+0x77/0x80
Feb 13 14:21:07 roy kernel: [<ffffffffb2b861c6>] start_kernel+0x44b/0x46c
Feb 13 14:21:07 roy kernel: [<ffffffffb2b85b7b>] ? repair_env_string+0x5c/0x5c
Feb 13 14:21:07 roy kernel: [<ffffffffb2b85120>] ? early_idt_handler_array+0x120/0x120
Feb 13 14:21:07 roy kernel: [<ffffffffb2b8572f>] x86_64_start_reservations+0x24/0x26 Feb 13 14:21:07 roy kernel: [<ffffffffb2b85885>] x86_64_start_kernel+0x154/0x177
Feb 13 14:21:07 roy kernel: [<ffffffffb1e000d5>] start_cpu+0x5/0x14
Feb 13 14:21:07 roy kernel: ---[ end trace ba22b8e8140ef448 ]---
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: transmit timed out, resetting
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000000: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000010: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000020: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000030: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000040: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000050: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000060: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000070: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000080: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000090: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000000a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000200: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000210: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000220: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000230: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000240: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000250: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000260: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000270: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000280: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000290: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000002a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000002b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000002c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000002d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000002e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000002f0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000300: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000310: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000320: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000330: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000340: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000350: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000360: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000370: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000380: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000390: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000003a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000003b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000003c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000003d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000003e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000003f0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000400: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000410: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000420: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000430: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000440: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000450: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000460: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000470: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000480: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000490: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000004a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000004b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000004c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000004d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000004e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000004f0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000500: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000510: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000520: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000530: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000540: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000550: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000560: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000570: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000580: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000590: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000005a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000005b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000005c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000005d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000005e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000005f0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000600: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000610: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000620: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000630: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000640: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000650: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000660: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000670: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000680: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000690: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000006a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000006b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000006c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000006d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000006e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000006f0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000700: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000710: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000720: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000730: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000740: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000750: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000760: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000770: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000780: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000790: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000007a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000007b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000007c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000007d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000007e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000007f0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000800: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000810: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000820: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000830: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000840: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000850: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000860: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000870: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000880: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000890: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000008a0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000008b0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000008c0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000008d0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x000008e0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c00: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c10: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c20: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c30: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c40: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c50: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c60: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c70: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c80: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000c90: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000ca0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000cb0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000cc0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00000cd0: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001000: 0xffffffff, 0x00000000, 0x00000000, 0x00000000
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001400: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001410: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001420: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001430: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001440: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001450: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001460: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001470: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001800: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001810: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001820: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001830: 0xffffffff, 0xffffffff, 0xffffffff, 0xffffffff
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001840: 0xffffffff, 0xffffffff, 0x00000000, 0x00000000
Feb 13 14:21:07 roy kernel: tg3 0000:03:00.0 enp3s0: 0x00001c00: 0xffffffff, 0x00000000, 0x00000000, .
