LAN adapter not found
Good point of view!
For many times I think in the same manner.
I think that NICs with Realtek chipset should works.
When you go to buy your Nic.
Ask the vendor if it’s lunux compatible… If the vendor not able to answer, take the permission to google the information.
if you can, buy NIC with intel chipset… fully supported, fast and reliable…
Always!
Like you (your logo show this), I’m an Intel fan.
well… if you take a look at my avatar… it’s not ā€œintelā€ :wink:
I know what is write inside of the avatar but the rest … And of course, because of what you write maybe you don’t like Intel at all! :wink:
@Jim, @GG_jr
With the link to the supported hardware I found the Realteck chipset of the adapter I will buy is supported.
@zamboni, @GG_jr
My computer shop didn’t have the LAN adapter in stock so I bought an Intel LAN adapter and it works :smile:
They would get the adapter next day but I need 30 minutes to drive one way and so it was cheaper to buy it for $30 more than to spent the time to drive there again. :wink:
Amazon, always :wink:
It isn’t a real option in Australia because it is all oversee (outside Australia). If I order something per internet it will need best case 3 days up to 4 weeks.
Only what works are ebooks :wink:
