I was curious once:
The option “Enable archiving via HTTP requests” in the Matomo WordPress plugin allows the archiving process to be triggered through HTTP requests instead of relying solely on server-side cron jobs or CLI commands. This feature is particularly useful for smaller websites or environments where configuring cron jobs is challenging.
Technical Implementation
1. Triggering via HTTP Requests:
• When this option is enabled, archiving is triggered by specific HTTP requests. A special parameter (trigger=archivephp) is used in the request to initiate the archiving process. This requires the request to be executed by a user with Superuser permissions.
• The Matomo API (CoreAdminHome.archiveReports) is utilized to start the archiving process, aggregating data from visit logs and generating reports.
2. Integration with WordPress:
• In the WordPress context, this feature can be enabled via thewp-config.phpfile by adding the following code:
define('MATOMO_TRIGGER_BROWSER_ARCHIVING', true);
This allows archiving to be triggered directly through browser activity or HTTP requests.
3. Asynchronous Processing and CURL:
• Archiving can be performed either synchronously or asynchronously. For asynchronous processing, a CURL request is used to execute the process in the background. This depends on server configuration and supported PHP settings.
4. Limitations and Recommendations:
• This option is ideal for websites with low traffic, as on-demand archiving consumes additional server resources and may increase website loading times.
• For larger websites with high traffic, it is recommended to automate archiving via cron jobs to ensure better performance
When the option “Enable archiving via HTTP requests” is disabled in the Matomo WordPress plugin, it changes how Matomo processes and updates reports. Here’s the technical implementation and what happens:
Technical Implementation When the Option Is Disabled
1. Disabling Browser-Based Archiving:
• Disabling this option corresponds to settingMATOMO_TRIGGER_BROWSER_ARCHIVING=falsein Matomo’s configuration. This prevents HTTP requests (e.g., from users accessing reports) from triggering the archiving process.
2. Switching to a Cron Job:
• Instead, a cron job must be set up to perform archiving regularly. This is done using the CLI commandconsole core:archive. An example cron job would look like this:
5 * * * * /usr/bin/php /path/to/matomo/console core:archive --url=http://example.org/matomo/ > /dev/null
- This ensures that archiving runs automatically and independently of user requests.
3. Asynchronous Archiving (Optional):
• If the server supports asynchronous archiving, Matomo can use this mode to archive reports in the background. Support for asynchronous archiving can be checked in Matomo’s diagnostics.
4. Configuration Adjustments:
• Additional settings can be made in theconfig.ini.phpfile underGeneralto further customize behavior, such as:
browser_archiving_disabled_enforce = 1
This ensures that archiving is exclusively triggered via cron jobs or CLI commands and not by HTTP requests.
Implications
• Performance Benefits: Disabling HTTP-based archiving reduces server load, especially for high-traffic websites.
• Manual Setup Required: A functioning cron job must be configured; otherwise, no updated reports will be generated.
• No Real-Time Data: Reports are only updated at intervals defined by the cron job.
