Hi Mario,
I myself have nothing to do with KVM, but I found this post: https://bugzilla.redhat.com/show_bug.cgi?id=874627
That sounds to me as if it were e.g. could be that the VM is emulating a newer CPU generation than the physical CPU. As a result, of course, some CPU commands are not available, but the guest tries to use.
Times so easy my first thoughts about it freely shot: slight_smile:
Are NethServer host and Mint guest working? Then the warning may be ignored. The workaround only disables the warning.
Looks like the problem is in host linux kernel kvm code, not in qemu.
Until kvm code is fixed, this works as temporary workaround:
echo 1 >/sys/module/kvm/parameters/ignore_msrs
I read mostly that it’s a warning to ignore but some people report about freezing systems too. Did you try to change the guest CPU as described in the link of @Hunv?
