KitchenOwl for ns8
Hi all,
I know this one is more on the personal/home use side but it would be great if NS8 could have KitchenOwl added to the app lust which is a great meal planning/grocery list app.
Details here: Getting Started - KitchenOwl Docs
I know there has been some work on using mealie - GitHub - phillopp/ns8-mealie: Mealie Integration for NethServer 8 however KitchenOwl has android/ios apps and seems more fully featured than mealie.
The self hosted implementation looks pretty straightforward, I am happy to help with testing.
Please consider this for a future feature :slight_smile: Thanks for your time.
I started a new project:
awesome thank you! @mrmarkuz
It’s ready for testing and should be available from Software Center after adding the repo, see GitHub - mrmarkuz/ns8-kitchenowl
You work quickly! Thanks again - will give it some testing over the coming days
I have been playing around and everything seems to work so far.
Is there a possibility this could be configured to use ns8 internal open ldap for the user accounts? Just a thought, not a hard requirement, manual creation is fine otherwise.
Thanks for testing.
LDAP seems not implemented, see Feature request: add ability to authenticate against LDAP database · Issue #28 · TomBursch/kitchenowl · GitHub
All good will wait for that to progress, app is still alpha so might be a while.
Thanks again for the work.
Just found myself in a situation that required a solution like mealie
So where are all these receipes then??? :wink:
dont worry ill steal you some days soon
